Want to install Adobe 9 but keep getting Error 1606
  • 89 Answers
Change the Microsoft Office install root location in the registry.Important: The following steps require you to modify the Windows registry. Modifications to the Windows registry, if not done correctly, can cause serious problems to a Windows operating system. The information is provided as a courtesy. This information has been found to cause the error message and should correct the error. If you have reservations about modifying the registry please contact Microsoft Office technical support. Back up the registry before making modifications. More information on how to back up the registry can be found on the Microsoft support site at http://support.microsoft.com/kb/322756.
  1. Click Start, and then click Run. The Run dialog box opens.
  2. In the Open field, type regedit, and then click OK. The Registry Editor opens.
  3. Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\[Version Number]\Common\InstallRoot and select the InstallRoot key. In the right pane, check for a value named Path.
  4. Right-click Path and choose Modify. Redirect the value to the local installation folder for Microsoft Office.
Posted on Jul 30, 2009
  • 23 Answers
Error "1606: could not access network location \Startup" occurs when installing Adobe Creative Suite 4 products or Acrobat (8 or 9)Check out this website for the fix to this issue.
http://kb2.adobe.com/cps/402/kb402867.html
2 Suggested Answers
  • 143 Answers
SOURCE: windows installer wont let download for adobe 9.1
try this soome reading to do
http://support.microsoft.com/kb/886549
Posted on Mar 17, 2009
There occurs an error while installing adobe reader which is about locating , the error number is 1606, n please do instruct me in that.
Hi Gopinathan81,
I have done some google work on the error code which you had and found the resolution..
Try this if it is not working then post back we will be happy to help you.
Hope this help.
Cheers!!!
Jan 22, 2011 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
Trying to Uninstall adobe 9 and get error code 1606.?
Install the latest version of Adobe and then uninstall the product.
Apr 22, 2010 | Computers & Internet
Was running Java Update and it came back with an Error 1606 and said that I needed %APPDATA% to complete setup....Can I get just that????
Hi,There are 3 step to repair 1606 error If you got 1606 error then there is a 94% chance that your computer has registry problems. To repair 1606 error you need to follow the steps below: * Step 1 - Download a Perfect Optimizer,install this error repair tool. * Step 2 - Click the Repair All Button.It will scan you pc for Free. * Step 3 - Then click the Repair All Button again and your done! It is very easy to repair 1606 error. Here are the url of Perfect Optimizer: http://www.errorremovers.com/tidporp-1606_error-zz0001
Nov 04, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
When trying to install keeps giveing error code 1606
Go to Start/Run/ Type in regedit.exe and then navigate to HKEY_CLASSES_ROOT\INSTALLER\Products\.
Look for the folder of the installer of the application you are having a problem with. Then simply delete the subfolder, reboot your system, and reinstall.
You should backup your registry first before deleting anything.
May 30, 2009 | Intel Computers & Internet
Error 1606: Can not locate network location; during Adobe Acrobat Reader 9.1 and Microsoft Office Standard Version 2007 install
On another computer with a cd/dvd drive hooked up to the internet Go to HP.com/support and, download the drivers for vista for your computer then install them on your malfunctioning computer
May 29, 2009 | HP Computers & Internet
Error 1606 with adobe
With many thanks to rlessmue on CNET forum... this is what worked for me (for both Acrobat Standard 8.0 & Photoshop CS2):
http://forums.cnet.com/5208-6122_102-0.html?forumID=44&threadID=106141&messageID=2913550
...I found an easier fix for "Error 1606" by rlessmue - 9/12/08 11:44 AM In reply to: Your suggestion worked! by jarjar467-news
Receiving "Error 1606: Could not access network location Startup"
To fix, Adobe seems to be having a conflict with Microsoft Office.
NO need to remove Microsoft Office (if you are having problems with install, upgrade or removal)!
Follow these steps:
1) Open Regedit, (Start -> Run -> (type in) regedit
2) Inside Regedit go to:
HKEY_LOCAL_MACHINE -> SOFTWARE -> Microsoft -> Office
3) Right click on "10.0" folder and select "Export" (and save a copy to your desktop).
(You can do this for the other number folders (like 9.0, 11.0, 12.0) if you want to be sure).
4) Verify that the file(s) have been put on your desktop.
5) Next, delete the folder "10.0" (or the folders you exported) from with in the registry (right-click - delete, confirm)
6) Install, upgrade or remove Adobe Acrobat 8.0...when done...
7) Go to the desktop and click twice on the "10.0" file (and each of the other files) and add back to the registry!
8) You should verify that MS Office products still work, and Acrobat should work too! That's it!
Dec 18, 2008 | Adobe Acrobat 7.0 for PC
Installing problem...
Try to see if you can resolve with the steps given here
first link
Second option
Apr 12, 2008 | Adobe Photoshop CS2 for PC
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
