I have a maytag stackable washer dryer I turn knob to wash nothing no water. I have to turn knob all the way to prince cycle then it starts spinning but still no water. What can cause this
Kenmore stackable washer dryer doesn't cycle (doesn't advance to water fill or wash, drain, rinse, spin) (not spinning, draining, filling?) After the video, we learned it was the points in the timer. It wasn't the black "electrical plug", being plugged into. Get your serial number and google Kenmore timer and you can order a replacement timer. Even if you still have someone come out, you've still saved a bunch!.......ps....I had a viewer make a good point!; I obviously didn't have any issues, but obviously be careful with electrical panel and any loose wires!
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
try looking at your pump or you need a cupler that goes on the back sid of the motor price range for the pump is 120 dollars and the cupler is 35 dollars dont quote me on the price of the parts please but that should fix the problem.
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
