2003 Ford F250 Super Duty Crew Cab Logo
Posted on Jul 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2003 f250 stuck in 4wd
2003 f250 crew cab 7.3 deisel stuck in 4wd
  • 1 more comment
  • philv3 Jul 30, 2009
    push button actually a dial
    Automatic
  • Anonymous May 11, 2010
    Automatic (electronic/push putton) or manual transfer case?
Timothy Merchant
Level 2:
New Friend:
  • Expert 175 Answers
  • Posted on Aug 29, 2013
Timothy Merchant
Expert
Level 2:
New Friend:
Answers
175
Questions
0
Helped
60312
Points
445
My for f250 is a 2003.and it did the samething.my deler toll me to turn the lock off and on 15 time to relese the vacuum on the front hub
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Aug 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2130
Points
Ck fuses,make sure veh. is in nutreal and make sure front diff.is not binding
Where is fuel relay 2003 f250 super duty crew cab?
check owners manual ,nut it might be in the power distribution box under the hood ,or behind the right kick panel under dash
4wd switch no power
FUSE/FUSE RELAY BLOCK/ OR SHIFT MOTOR// START WITH FUSES AND THEN RELAY BLOCKS. AND THEN SHIFT MOTOR LAST.. GO TO A PICK AND PULL SCRAP YARD FOR THE SHIFT MOTOR AND RELAY BLOCKS..
Fan quit working on ac , compressor still working
FUSES, RELAY FOR THE A/C OPERATION. ALL SPEEDS STOP WORKING????
I am smelling antifreez in my exaust smoak would it be head gaskets or the inter cooler this is a 2003 ford deisel
first we need to know what engine you have! i am going to guess the 6.0 ltr if you are having this issue. If so it is probably your EGR cooler. Sits inside the v section on top on the right side. This is a common failure on the erlier versions of this motor!
1helpful
2003 ford F250 6.0 deisel..it will crank but will not start,cam and crank wil not synchronize..both are new. oil gauge wil not show pressure while cranking RPM.is around 48 rpms on a scan tool...
I HAVE A 7.3 DEISEL AND I DONT KNOW IF THE 6.0 HAS ONE OR NOT BUT MY CRANK SHAFT SENSOR WENT BAD AND THE TRUCK WOULD NOT START( JUST TURN OVER ) DEALER PUT NEW CRANK SHAFT SENSOR ON MINE AND FIXED THE PROBLEM...HOPE THIS HELPS...
1helpful
4wd won't work on 2001 F250
somethig is unpluged from the trans or t-case. get lookin at all wires goin or comin from them. good luck.
Manual 4x4 is stuck
check the vacuum switch and lines...
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
