Question about AT&T Nokia 6555 Cell Phone - Black
The phone turns on then it goes off and then the date flashes on and off and eventually the phone dies
What can i do to fix a blu phone. the logo flashes then dies, continuously
Hi Juan, The link below is a YouTube video showing how to fix your phone/tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
How To fix any Android Phone Tablet that won turn on
May 12, 2016 | Blu Dash 5.0 D410a Unlocked GSM Dual-SIM...
When driving the radio died then the car died wouldnt start again wont even turn over
It sounds like your alternator went bad. The alternator is responsible for keeping your battery charged and at full power. If it goes bad, your battery eventually drains and things start to shut down.
Get your alternator and battery tested, I'm sure you'll find the alternator has died.
Oct 19, 2010 | 1994 Nissan Altima
Phone won't turn on at all
take the battery out then try again. If the battery isn't totally dead try turning the phone on and then plugging it in. It's happened to me before and sometimes it takes a few tries to get it to work but it should come on eventually.
Mar 11, 2009 | Samsung SGH-a737 Cellular Phone
Rpm's fluctuate when trying to idle and eventually dies
check for vacumn leaks, hoses, and intake. check idle air control valve for proper operation, if you have check engine light run codes by shorting diagnotic terminal and turn ignition to run. Should flash any codes in system.
Dec 14, 2008 | 1993 Geo Storm
Flashing Unit for Indicators Replacement
Most likely it's the hazard switch - the relay for the hazards and the turn signals is built into it. When they start to die, you will see erratic behavior with the turn signals and/or hazards, and eventually they'll both fail completely. Replace your hazard switch on the dash and you'll be good to go.
Aug 31, 2008 | 2000 Audi TT
Charging problem!!! PLEASE READ!
as i think that charger was not compatible to your phone so when you tried charging it the battery is dead bcoz of excess voltage than it normally bears with the compatible charger of ur phone ...
so this excess voltage has made the battery to be short circuited due to this may be the charging ic or the capacitor is gone ...
so i suggest you to take the cell to the near by technician and just have a check...
the only problem with all motorola phones is that it only charges with the charger with the desired voltage ... if the voltage of the charger is low then it will not show any response(i mean it will not charge but it will not cause any thing to battery as it is of less voltage than the desired voltage )
so i think the charger you buyed provides more than the desired voltage so the battery is dead .....
Feb 07, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Turns on and turns off
I have the same phone and it is doing the same thing, i called about it and i was told to bring it back to the dealer as it needs to have it's software up dated, he called it a "flash" I haven't had it done yet but will report back when and if it works for me.....
Oct 14, 2007 | LG Chocolate Clamshell VX8600 Cellular...
AT&T Nokia 6555 Cell Phone - Black Logo
89 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
