Question about Frigidaire FGR341AC Electric Dryer
HOW DO I GET TO THE HEATING COIL - Frigidaire FGR341AC Electric Dryer
    Scholar:
  • 76 Answers
Whats the model number? better yet go to this website www.partselect.com enter your model number and it should pull up diagrams of your dryer. Very useful site when trying to find parts and stuff. Hopefully this helps.....
Posted on Jul 30, 2009
Heating coil
No matter if u not findout the inside or outside coil then u can check by multimeter its positive or -ve points
Jun 09, 2013 | Hotpoint Aftermarket Clothes Dryer Heater...
Iron has stopped heating
Check the power connection, the power cord to the heating coil. If there is no suppy then check the bimetal contact of the temperature setting switch, if voltage comes to coil without heating, the coil can be open .
You will have to use a multimeter in Ohms range to check the continuity of the coil.
Have to decide is coil is open about the cost of coil to that of a new iron.
Oct 05, 2010 | Euro-Pro Shark GI490 Iron
Heating element. How about just replacing the coil?
you can get a re-string kit if its the open type heating element round pan style and re-string it yourself for about $30-$40
May 27, 2010 | Dryers
TUMBLE DRYER NOT HEATING UP
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil. You should read continuity across the terminals, if not you will need to replace the coil as it is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine. I will include these two websites for parts and further help:
Dec 04, 2009 | Dryers
My dryer has stopped heating, it still spins but thats about it.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Oct 20, 2009 | Roper Dryers
Not heating
Good Luck,
Hope this helps
Oct 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dryer isn't heating up
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Good Luck,
Hope this helps
Oct 14, 2009 | Kenmore Dryers
Dryer is not heating up
Good Luck,
Hope this helps
Oct 14, 2009 | Whirlpool LER4634J Electric Dryer
The dryer is running but not heating
Good Luck,
Hope this helps
Oct 11, 2009 | Kenmore Dryers
Dryer not heating ''clothes still wet''
Good Luck,
Hope this helps
Open Questions:
See all Frigidaire FGR341AC Electric Dryer Questions
Frigidaire FGR341AC Electric Dryer Logo
109 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
