Central air cond. was working fine 5 hours ago it went off and wont come back on. the thermastatis not lit up. it does nothing.when you try to turn air on, nothing happens at all
    Scholar:
  • 117 Answers
First ,you should verify thermostat has good batteries.secondly ,you should check to make sure the circuit breaker isn't tripped. If both of these give no results and you feel comfortable digging around the unit yourself, you will have to access the sevice panel on the outside unit to verify voltage from transformer. You should check the secondary side of transformer for 24 volt ac, as this is what feeds power to your thermostat . Hope this helps
Posted on Jul 30, 2009
Hi i am getting an error on my fujitsu aotrcf3l ductud system it is eof abnormal discharge temperature. it was working fine in 42 degree heat 108f and the power went out for about an hour the house heated...
Condenser coil is blocked by full of dust.-Clean it. Fan motor less rpm -Replace capacitor. As you said, 1 minute running compressor due to weak capacitor. Replace running capacitor and clean coil with water and then check. Hope, helpful.
Jan 30, 2011 | Fujitsu Heating & Cooling
Central air not working
the pilot light has nothing to do with the operation of the central 'air' system.
As to the central 'heat' system however, it must be lit.
hope this helps.
Jun 13, 2010 | Goodman CLQ36AR49 Air Conditioner
How to turn on a weatherking gas furnance
Make sure the thermostat selector switch (located in the thermostat board by pulling out the front) is on the gas position.
Oct 05, 2009 | Weather King 10AJA3601AH Air Conditioner
Sidekick lx2009 wont turn on & when charging it turns on & OFF!
try plugging it in to the computer or try a new battery
Sep 01, 2009 | Sharp Sidekick LX Smartphone
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
89 Honda Prelude SI- Wont start
sounds like your on the rite track . clean the contacts at the batt and at the starter and get back to me
Feb 19, 2009 | 1990 Honda Prelude
Garmin NUVI 200w
the same issue with mine, but mine cut out after one day. Purchased 6-9-08
Jun 09, 2008 | Garmin nuvi 200W GPS Receiver
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
