Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
How do i lock my wireless router so that my neighbors cant use my signal
    President:
  • 828 Answers
To lock or put a password on your Wireless Router is you have to get the Gateway Address of your Router (Firmware) like for example: http://192.168.0.1, to check it in your LAN Network Connection.. Check it there, then go to your Internet Explorer and type it on the Address, (http://192.168.0.1) the ENTER then LOGIN: admin PASS: admin,
To get into your Router Firmware and read all the instruction if you get in to put a password on it.
Posted on Jul 30, 2009
The signal from my router to my Samsung blu ray is not strong enough
There are several things you need to consider with wireless connection:
Distance - How far is the Netgear router from the Samsung Blu ray? Try changing the wireless channel on the Netgear router that can help boost the signal. Wireless Security- Have you enabled wireless security on the router? Is it WEP or WPA? Make sure that you input the wireless security key on the Blu Ray player and that you have setup wireless settings correctly.Number of wireless devices - Check the number of wireless devices(laptops, desktops, pda's, etc) connecting to the router as it also weakens the signal. And if wireless security is not enabled on your Netgear router, there's a chance that your neighbor might be connecting to your router via wireless.
You can also test how strong the signal is by placing a wireless laptop on the same location where the blu ray player is. If the laptop gets a weak signal as well, you can try placing the router closer to the blu ray player.
Oct 24, 2011 | NetGear WNR2000 Wireless Router
How can i lock my router so that my neighbors cant use it?
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Sep 03, 2010 | D-Link DIR-615 Wireless Router
Using linksys wrt54g router i using the wired section with two computers and the signal only dropping
There are many causes for poor wireless connections, and many solutions:
First of all, give your network a unique SSID. Do not use "linksys". If you are using "linksys" you may be trying to connect to your neighbor's router. Also set "SSID Broadcast" to "enabled". This will help your computer find and lock on to your router's signal.
Poor wireless connections are often caused by radio interference from other 2.4 GHz devices. This includes wireless phones, wireless baby monitors, microwave ovens, wireless mice and keyboards, wireless speakers, and your neighbor's wireless network. In rare cases, Bluetooth devices can interfere. Even some 5+ GHz phones also use the 2.4 Ghz band. Unplug these devices, and see if that corrects your problem.
In your router, try a different channel. There are 11 channels in the 2.4 GHz band. Usually channel 1, 6, or 11 works best. Check out your neighbors, and see what channel they are using. Because the channels overlap one another, try to stay at least +5 or -5 channels from your strongest neighbors. For example, if you have a strong neighbor on channel 9, try any channel 1 through 4.
Also, try to locate the router about 4 to 6 feet above the floor, in an open area. Do not locate it behind your monitor or near other computer equipment or speakers. The antenna should be vertical.
Also, in the computer, go to your wireless software, and go to "Preferred Networks" (sometimes called "Profiles" ). There are probably a few networks listed. Delete any network named "linksys". Also delete any network that you do not recognize, or that you no longer use. If your current network is not listed, enter its info (SSID, encryption (if any), and key (if any) ). Then select your current network and make it your default network, and set it to automatic login. You may need to go to "settings" to do this, or you may need to right click on your network and select "Properties" or "settings".
If the above does not fix your problem, download and install the latest driver for your wireless card.
Some users have reported improved wireless performance by switching to WPA encryption.
If you continue to have problems, try the following:
For wireless g routers, try setting the "Transmission Rate" to 54 Mbps.
If you still have trouble, download and install the latest firmware for your router. After a firmware upgrade, you must reset the router to factory defaults, then setup the router again from scratch. If you saved a router configuration file, DO NOT use it.
Aug 24, 2010 | Linksys Wireless-G WRT54G Router
Cant get wireles signal, i just switched service providers and can not pick up wireless signal.
Do a channel scan before you call provider and ask them to change it to a channel number that is not being occupied. Ask you provider to change your channel number on your router? You and your neighbor is sharing the same channel number. One is over powering the other.
Dec 09, 2009 | Linksys Wireless-G WGA54G 802.11g/b...
Iget two network icons one says 71 percent the other says 91 percent the 71 is unlocked but the 91 pecent is locked and when I clic it it does not work
There is two wireless networks that is in your neighborhood. One must be a stronger signal then yours. The reason why your is not working is, your neighbor's wireless is on the same channel as you are. Try changing channel number on your router.
Dec 06, 2009 | Linksys Wireless-G WRT54GS Router...
Wont get a signal or my wireless wont recongnize the zonet router 1104we cant get anything from it at all..thanks for helping me if u can
1. Try a power cycle / reset of the router, if it is not transmitting signals 2. If your computer is not getting signals at all, ( not even your neighbor's ) , try uninstalling the wireless card and installing it again 3. Make sure you the wireless switch in your computer turned on
Thanks Ranjit
Sep 24, 2009 | Zonet ZSR1104WE Wireless Router
Need help using router
First of all your neighbor must be able to reach your signal. When they start up their wireless application they must be able to see your SSID, and have enough signal strength to actually connect and do meaningful work. This might be the case already, or you may need to put in a repeater closer to your neighbor. You r neighbor could also purchase an external directional wifi antenna from radio shack to improve reception. I have used Cantennas (look like a Pringles Can) before and they work ok.
Once you have signal then you just need to give your neighbor the password to your wifi network for them to enter into their network application. This password was setup when you setup the wireless network. You probably wrote it down, or it is a common password that you use.
The rest should be seemless, depending on the signal strength.
Nov 11, 2008 | Linksys Wireless-G Broadband Router
My neighbor's signal
If your neighbors know that your using their router, you might ask them to reset it. If they moved it, this could cause the weakening of the signal, walls drastically decrease a wireless signal. You might also refresh your wireless card by uninstalling the wireless drivers and reinstalling them.
Aug 05, 2008 | HP Compaq nc6000 Notebook
Everyting seems right but not working
Hey, Call your Internet connection Company for support because you might have the wrong input in the lock box, so call!!!
Oct 31, 2007 | Dell TrueMobile 2300 Wireless Broadband...
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
1,058 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
