Question about D-Link DFE 916 (DFE-916) Networking Hub
Is 30meters UTP cable are able to connect to hub or switch?? Thanks!! Adam
    Scholar:
  • 103 Answers
Yes you have up to 100m. More info and standards http://en.wikipedia.org/wiki/TIA/EIA-568-B
Posted on Jul 30, 2009
When i get connected to d-link des 1008d switch port the computer will get automatically configured 255.255.0.0 to subnet mask therefore i have class c ip address and i dont have internet connection...
u no need to worry about the subnet mask 255.255.0.0
just do the following connections
  1. connect a utp cable from modem/router to dlink switch.
  2. connect a utp cable from switch to ur pc
Assign ur pc manually with following configuration
ip: 192.168.100.5
subnet: 255.255.255.0
gateway: 192.168.100.1
and your router with ip: 192.168.100.1 And enable pppoe in ur router.
Thats it you are connected to internet. No need to enable ics etc.
Jul 05, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
After unplugging the UTP cable the LED stays,Cisco 3560 Poe 48por
The light may stay on due to static in the switch. It will automatically go off after some time when the static gets discharged.
Apr 29, 2010 | Cisco Catalyst 3560-E 24-Port Gigabit...
How to share one utp connection into two
for 10/100 connections you can do this (look on eBay for "Lan Splitter cable"). This is because for lower rate Ethernet there are spare pairs of wires in the cable. If you intend to run 1GBps then it needs all of the pairs in the cable and you will not be able to use the splitter.
The better solution would be to either use a switch in the room to break out the one cable you already have, or to run a parallel cable. As you may need extra LAN connections in the room in the future, the switch is generally the best method.
If this helps, please leave feedback - if not let me know and 'll try and help some more
Jan 29, 2010 | Computers & Internet
STP cables - with - Linksys Ethernet 5-Port Workgroup Hub
Most liklely you shouldn't do this unelss you are willing to do the work to properly ground the cables on each end. I'm pretty sure your hub iuses a DC power brick so it won't handle it for youm you'll have to build a breakout box of some sort to do this. Remember that if the cable isn't grounded properly on each end it will actually make things worse.
Running at 10M with Cat 6 cable it is highly unlikely that you will have issues with electrical interferecne even with the the undesirable routing of the cables in your house.
Aug 21, 2009 | Computers & Internet
I CANT GET CONNECTED TO BT HUB
have you typed the key exactly? viz uppercase/lowercase. The switch(hub) might have MAC address filtering on. also check if the switch(hub) has a DHCP running, which allocates IP addresses, if not you need to set your wireless connections IP address within the same range as the switch. If all else fails attempt to connect the switch via a utp network cable which should have been suplied with the switch(hub) so you can access the switch and make the necessary changes... email me on djtracer@vodamail.co.za should you need more info.
Aug 11, 2009 | Computers & Internet
HP Procurve 1700-8 working upto 10m UTP cable only.
It is not a distance limitation of the switch, rather the cabling in the walls and ceiling. If the cable is Cat5 it can be up to 100M, but this can be drastically reduced with things like EM interference from fluorescent lights, kinks in cable and more. The switch auto detects the maximum reliable speed and this interference would cause it to drop to 10MBps. If you don't have a cable certifier (very expensive) you may want to consider simply replacing the cabling run with Cat6 following best installation practices. You can learn more at http://www.lanshack.com/cat5e-tutorial.aspx.
Feb 14, 2009 | HP ProCurve 1700-8
Connect to Konica photo copier/prtr with Belkin F1B024-E switch
if you're using a utp straight through cable, just connect your 2 pc to your switch then install supporting software to both pc.. then go to control panel then printer and faxes and find printer..
Feb 10, 2009 | Belkin Bitronics Data Switch Kit [...
Network
Also you would to configure the TCPIP address and network name for each PC so they can share data etc.
May 09, 2008 | Computers & Internet
Connection Problem
maybe its not in the hub/router, or in your lancard has the problem. try to change the networking cable you are using it sometimes the cable has a teared wire inside, or probably the lancard or your hub does not work for the type of networking cable, there are 2 types of connection for UTP cable first is the Straight through cable and the second is the Cross Over connection. Try to mix and match the cable that you have and try to use another one instead..
Nov 19, 2007 | Cnet CNSH-1600
D-Link DFE 916 (DFE-916) Networking Hub Logo
121 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
