Question about LG Dare VX9700 Cell Phone
Rhapsody doesn't transfer files
I have a LG NV touch and am running rhapsody. It plain old doesn't do anything. Thoughts?
I cant transfer anything from LG 500 touch phone to laptop is there a programme i need to download please
LG suite is the best option. there are some protected things e.g ringtones you might not transfer. other wise get a card reader and transfer your files to pc with the memory card in the cell
Jun 11, 2011 | LG Cell Phones
My sansa fuze is telling me i need to synchronize to continue music subscription? What do i do?
Hi There. I can understand your problem.
When we say synchronize it means that the license for the songs which you transfered got expired. If you have chosen rhapsody for transferring songs then follow the steps.
1) Deauthorize Computer. ( In rhapsody menu, go to tools menu there u will find this option)
2) Deauthorize device (By connecting the device in to rhapsody, right click on device where u will get this option).
3) Rename DRM folder in windows OS.
4) Go to rhapsody folder c:/prog files/rhapsody
5) Run the 3 files ( Del Helix License, Update Helix Componetns and Update windows components)
6) Then you will be redirected to the web page where u need to click on upgrade (But before u clilck on upgrade please install the activeX control, which will be popped up below the address bar)
7) Restart the computer
8) Launch rhapsody, it will take u to the setup
9) Follow the on screen instruction.
10) Sign into rhapsody account
11) Authorize computer
12) Connect the device
13) Authorize device
14) Download and transfer new song into the device
15) Unplug the device and try to play it
16) This should work..
NOTE : When we update the windows component please make sure that we use IE as default browser
Still if u have any issues kindly revert
Jan 12, 2010 | SanDisk Sansa Fuze MP3 Player
New update from Rhapsody, messing me up
I would recommend reinstalling the original software/drivers. You can find them here.
Dec 26, 2009 | Insignia NS-DV2G MP3 Player
Can't find clip in my computer
This is and excerpt from "EphMusicFan" on the Real player forum. Original link is also below.
" The following steps finally fixed everything for me. While it may seem long, it only takes about 15 minutes and should fix everything.
If you run windows XP don't have Windows Media Player 11 installed, download and install it here,
http://www.microsoft.com/windows/windowsmedia/player/download/download.aspx
Run Windows Update, and install all high priority and optional updates related to Windows Media Player or device synchronization.
On XP, the updates include:
Update for Windows Media Format 11 SDK for Windows XP (KB929399)
Security Update for Windows Media Player 11 for Windows XP (KB936782)
Update for Windows Media Player 11 for Windows XP (KB939683)
Security Update for Windows XP with Windows Media Format Runtime 9.5 and 11 (KB941569)
Open Rhapsody
From 'My Account' menu select de-authorize computer
Close Rhapsody
To delete the mcs.rma file:
1. Close RealPlayer/Rhapsody
2. Click the Windows Start button. Then click Run.
3. Type %windir%\system32\ and click OK.
4. Find the mcs.rma file.
5. Right-click mcs.rma and select Delete.
6. Close the window.
To delete the basi3260.dll file:
1. Open the My Computer icon on your desktop.
2. Open the C: drive (usually Local Disk (C:\)).
3. Open the Program Files folder.
4. Open the Common Files folder.
5. Open the Real folder.
6. Open the Plugins folder.
7. Find the basi3260.dll file.
8. Right-click basi3260.dll and select Delete.
9. Close the window.
10. Restart your computer.
on sansa Clip itself, disconnected from computer, go to settings, then choose format
Make sure Rhapsody, Windows Media Player, and all other media programs are closed
download firmware
http://forums.sandisk.com/sansa/board/message?board.id=clip&thread.id=2946 (make sure you get 'Americas' firmware version)
unzip firmware file
connect to computer
drag firmware file onto sansa Clip icon in Windows explorer
wait to finish all copying (Sansa Clip screen will say connected, not writing or reading)
disconect
firmware updates on device, then it shuts off automatically
turn it back on
reformat from device (settings menu, format)
put in msc (under USB mode on settings menu)
reconect
open sansa Clip E:/ in Windows explorer, delete all files (should be 6-8 folders and files in top level directory of Clip)
reformat from windows explorer (right click, format, (FAT file system, NOT FAT32))
disconect
put in mtp (under USB mode on settings menu)
Open Rhapsody
It will run through quick setup again, due to files deleted before.
'Reathorize Computer' (under 'My Account' menu)
"Update Track Licenses' (same menu)
connect to computer
wait for Rhapsody to fully load clip (may take 30 seconds)
reformat from rhapsody (right click on sansa clip icon in rhapsody, select reformat)
hold down control and shift buttons at same time, right click on sansa clip icon in Rhapsody, select 'reset secure clock'
right click on sansa clip icon in rhapsody, select authorize device
wait while sansa clip updates (wait for screen of device to say 'connected' for a while, rather than writing or reading)
disconect
reconnect
wait a while updates finish
disconect
verify acount, and dates on device, under setting menu, account
should say renewed (with today's date) expires a date 30 days later.
download one new track from rhapsody you never have downloaded before
reconect
transfer that one track to clip
wait for all updates to finish
disconect
verify account, dates on device, check that the track plays properly"
Hope that helps.
http://real.lithium.com/real/board/message?board.id=InstallingRhapsody&thread.id=26724
Feb 05, 2009 | SanDisk Sansa Clip MP3 Player
Problems with transfering music files
This player doesn't work well with rhapsody - I would get songs in mp3-only format.
Dec 03, 2008 | RCA OPAL M4001 MP3 Player
Sansa c250 and rhapsody
I first suggest that you use Windows Media Player on transferring songs to the player. Rhapsody is a p**n in the a** when i use it to transfer songs to the player. Well back to the topic, make sure the device that you have is set to MTP when you are transferring songs to the player using rhapsody.. If it will not transfer format the player using Settings and then FORMAT if it did not work format the player in MSC mode. To do this, go to settings then to USB MODE then change it to MSC and then connect the player to the computer. After connecting the player to the computer ti will be detected as a removable disk drive. Right click on it then choose FORMAT make sure the file system is FAT32. THen after the format is done. Chnage the mode back to MTP then transfer a song using rhapsody. If all else fails using the windows mediaplayer program. Here are the instructions on using the windows media player program.
http://www.sandisk.com/Retail/Default.aspx?CatID=1468
Aug 08, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Need file transfer Software!!!???
You do not need any specific software to transfer music. You can Drag and Drop files thru Windows XP or Vista, or use Windows Media Player 10 or higher, Rhapsody, or several other music management programs.
The only software on the CD was Rhapsody, or the Best Buy Digital Media Store. Both of which are on the internet.
http://www.rhapsody.com/-software
or
http://www.rhapsody.com/download.jsp?from=bbdms
Best of Luck.
Oct 13, 2007 | SanDisk Sansa e250 MP3 Player
Sansa turns on but does NOT do anything!!! :0!!
Sounds like you have a few different problems, thankfully its easy to resolve. Run the recovery tool from the SanDisk website, select FORMAT when prompted. http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe Best of Luck. (this only works with non Rhapsody devices, annotated by an 'R' or the word Rhapsody on back)
Sep 09, 2007 | SanDisk Sansa e260 MP3 Player
Please help me!!! im desperate!!! sandisk sansa e260
if your sanas e260 does'n syncronize with your computer or say data base..., take the battery out and conect it with out the battery.
May 08, 2007 | SanDisk Sansa e260 MP3 Player
LG Dare VX9700  Cell Phone Logo
66 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
