Question about Canon Pixma MP480 All-In-One InkJet Printer
Won't Print The printer is hooked up directly to the computer via a USB but when I select file print nothing happens. The computer picked up the printer and it makes copies and prints photos. Help!
Unplug the printer Goto Device Manager, uninstall the USB print support device, reboot, plug the usb cable back let windows auto detect the device (Printer) Install drivers from CD if necessary then try it again.
Posted on Jul 30, 2009
    Sergeant:
    Champion:
  • 283 Answers
Reinstall the driver of the printer.tnx
Iogear GUB231 won't pass printing command
Make sure you are selecting the printer after you hit print button. Sometimes there are other printers listed that are not installed and you end up sending spool to them. Also make sure you set the printer
Dec 28, 2012 | IOGEAR TECHNOLOGY IOGEAR GUB231 - USB...
How do i print my contact list from my phone
u need a bluetooth printer for it. if u have a bluetooth enabled printer u can print it directly from phone by selecting print.
if u dont have that, if u have computer connected printer, connect ur phone to computer & print it then, the file will automatically be printed from ur phone to printer via ur computer...
Aug 27, 2009 | Nokia 3110 Cellular Phone
My Design Jet 1050c does not like to print PDF's. It says receiving low memory right now and is taking an extremely long time
Two questions:
1. How large is the PDF file and is saved on your local hard drive?
2. How is the plotter connected to your computer? Network or directly connected via parallel or USB?
Try changing how the printer processes the print job.
On the driver properties / preferences, select the Advanced tab and change the Process Document to "in computer" and then try printing again.
Aug 06, 2009 | HP DesignJet 1050c plus InkJet Printer
Dell a920 network problem
I will assume you have the Printer connected directly to a PC via the USB printer cable on our network.
a. Start - Run - Control - Ok
b. Open 'Printers and Faxes"
c. Open "Dell A920"
d. Print "Test Page" to assure the printer is working and connected.
e. With the "Dell A920" properties open - find the tab for Sharing.
f. Now select Share the Printer and name it.
At each Workstation you will need do steps a-b, and add the printer. Select browse network when adding the printer and find the Workstation with the shared printer.
If your Firewall on each Workstation is blocking "Print and File Share" you will need to change the settings to allow this procedure through.
Here is a link that may help further.
http://www.smartcomputing.com/Editorial/article.asp?article=articles/webonly/techsupport/73w10/73w10.asp&guid=
Hope this helps.......
God Bless.......
Jul 28, 2009 | Dell A920 InkJet Printer
Cant print off compute
Hi Grubeman,
The issue seems to be with the printer drivers. To confirm whether the issue is with the printer drivers or with the application, try to print from all the other applications and check for the result.
I have two solutions for your issue.
1. Set "print directly to the printer" option
2. Alternate drivers.
To set the Print directly to the printer option, do the following steps.
1. Open the printer folder
2. Right click on the printer icon and select properties.
3. Click on the Advance tab and select "print directly to the printer" option.
4. Click apply and ok.
5. Nothing else, just try printing dear!!
The second solution, I will post, once I found that the above steps does not resolve your query...
BYE.....
Feb 05, 2009 | HP Officejet 5610 All-In-One InkJet...
Can't print to mac wirelessly (could do it a few days ago)
I had the same problem until recently. You have to install the drivers FROM THE CD that came with the printer, instead of selecting the drivers from the default list. Then, when selecting which printer driver to use (you'll have two options) choose Canon IJ and NOT Canon MX310 series. This is a problem with their MX310 driver, which is solved using a default/generic Canon InkJet (hence, the IJ) driver. Hope this helps!
P.S. This only works on Mac OS X. I have yet to figure out how to print wirelessly through Vista. Will keep you posted.
Mar 28, 2008 | Canon PIXMA MX310 All-In-One Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
Canon Pixma MP480 All-In-One InkJet Printer Logo
111 people viewed this question
old marine
old marine
