Question about Mitsubishi VS-60707 60" Rear Projection Television
Had horizontal Lines replaced now have error 21 xray circuit
I replaced the caps as I was told to fix one problem and now have a non turn on with a x-ray circit issue cant seem to figure this one out
  • budiceman Dec 05, 2007
    any other help with the error Im getting with the unit. where to start with troubleshooting the diagnostic code 21
  • budiceman Dec 11, 2007
    can anyone help me out before I take a ax to it
  • 244 Answers
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Posted on Nov 24, 2007
I have a mit WS65411 shutdown error code 21
thats the error code for Xray protection which is usually indicating an issue with one of the CRTs and the safety shutdown kicks in and the 21 error will be stored.
Feb 05, 2013 | Televison & Video
Code 21
Try the crankshaft sensor
Jan 01, 2018 | 1991 Nissan 300ZX
After pressing the remote to turn tv on, the tv comes on for about 3 to 5 seconds and then turns off
Going into xray protection mode. B+ line too high. Look for open resistor in horizontal output circuit.
Nov 16, 2011 | Televison & Video
My LCD TV works at first, then shows stripes
My Polaroid LCD Combo set would scare me with loud squeeling sounds and the picture was messed up...
I read the discussion by SteveO who said to replace caps that have leaked or buldged out showing that they were bad...usually in the power supply when the symptom was no picture at all. I couldn't find any buldging caps in my set so I made a phone call to Polaroid and told them my set that had vertical lines with orange or pink colors and asked what the problem could be. The guy said if it had horizontal lines it could be a problem with a cable box or antenna or the reciever/ tuner, which could be fixed...but vertical lines...that is a problem with the LCD screen and I would be out of luck. "It's not worth fixing" he said. They offered me a re-furb for $225.
Then I remember what a tv repairman told me about a on-going problem Zenith had with their sets. He said they had a batch of lousy solder that degenerated after a few years of use leading to loose connections. He told me to heat up and resolder all caps and resistors on the boards. That might fix it. I had a problem with my Polaroid LCD TV that had no signs of bulging caps so I just used my soldering iron on the underside of the board heating up any place I saw caps or bigger components installed. BE CAREFUL not to touch any of the integrated curcuits or chips, just the stand alone components. When I turned the set on the picture and sound came on and did so ever since. No more turning off the set and turning it on again. Done done ! DONE.
Apr 14, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
I have a sharp tv 21" if i turn it on or change channel,pink display will appear with red horizontal lines about half inch intervals dn a few seconds it will turn normal but the red horizontal lines remain...
my sharp tv was like that to but our tv color was blue with also gray horizontal lines i did cheack all d caps resis... etc dont know what to do LoL.
Feb 07, 2010 | Sharp Televison & Video
Mit. WS-65315
A 21 code in mitsubishi is indicating that the set is shutting down for Xray protection. Which means voltages are rising and triggering a shutdown for safety reasons. You will need to trouble shoot the Xray circuit to locate the problem.
Jul 03, 2008 | Televison & Video
Partial horizontal collapse. Nu-tec Model NTT-829A
If you have retrace lines I would recheck all caps around the vertical IC 100@16 is the most common 47@35 and 220@35
May 30, 2008 | Televison & Video
Horizontal lines when I turn on tv.PT-53X42 HDTV
Get the professional, although this won't be an expensive fix... You likely have one or more caps in the vertical circuit that are going bad... A cap acts like a battery in a circuit taking on voltage and releasing it at an even rate. When they go bad their ESR (equivilent series resistance) rises and the cap takes longer to reach it's op temp and work properly...
A tech with an ESR meter will easily find and repair this one... But you'll need to take it in to save the pickup/delivery charges.
Good Luck!
Aug 24, 2007 | Panasonic PT-53WX42 53" Rear Projection...
TV "X-Ray" Error
HI Matt of south Africa Every Tv has an xray protection circuit.that circuit is faulty os you will have to take it to qualified tech to repair your tv.good luck.
Apr 26, 2007 | JVC AV-A21M3U 21" TV
Mitsubishi VS-60707 60" Rear Projection Television Logo
173 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
