Question about Garden
Craftsman 22inch hedge trimmer clutch removal,recoil replacement
How do I remove the clutch on the craftsman hedge trimmer so I can replace the recoil rope?
3 Suggested Answers
SOURCE: craftsman hedge trimmer fuel line replacementa craftsman
My Sovereign SHT 26 hedge trimmer has a damaged fuel pipe which needs replacing; please advise
Posted on Jul 16, 2011
  • 11 Answers
SOURCE: cant remove pull rope housing from homelite gas hedge trimmer
there is a screw in the hole of the clutch housing bell torx bit i think its a #20
Posted on Jun 07, 2012
Hedge trimmer pull string replacement
you have to remove the recoil assy... If you can get that far then you can fix it, if you cant dont try
Nov 30, 2013 | Electrolux Garden
Cant remove pull rope housing from homelite gas hedge trimmer
Jun 04, 2012 | Garden
I have a 22inch Craftsman Hedge Trimmer, Model No. 315.81591. When trimming a hedge near a chain-link fence, one of the steel links from the fence got caught between the blade guard and the cutter blade. ...
The likely issue is the gear pin has been sheared. The part is no longer available from Craftsman. (P/N from sears: 616255-001)
I had a similar issue with a similar electric trimmer. I removed the old pin and used a split pin and ground it down to the proper size. It's now worked for about 2 years just fine. This requires complete dis-assembly.
Sep 27, 2010 | Craftsman 22 in Hedge Trimmer
My craftsman pull cord broke on my weedwacker
Remove the tube that holds the flex drive from the end of the crankshaft. Lossen and remove the front cover. Remove the throttle cable from the carb. Remove the kill switch wire from the coil module. Remove clutch housing. Remove clutch, Remove flywheel. The recoil unit mates with the bottom of the flywheel and all the aforementioned parts are on the front side of the engine's crankshaft. Once you get the recoil unit off, you remove the old cord and turn the unit several times to "preload" tension on it. Insert the new cord into the guide holes and tie knots to lock it in place. The pull handle must be attatched too or when you let the recoil draw in the new rope, it will keep going and all tension will be lost. Reassemble all the above and good luck
Aug 31, 2010 | Craftsman Garden
Craftsman hedge trimmer fuel line replacementa craftsman
Jun 12, 2010 | RTO Weed Eater Hedge Trimmer 20cc,...
I'm having problems figuring out how to change or repair the string pull on a craftsman 22 inch gas hedge trimmer. It looks to me like you have to remove the clutch. How do you do that?
remove screws on both sides of plastic housings, remove spark plug, pull off plactic cap on the bottom side of the clutch plate. stick a wooden stick in that hole to keep the crank shaft from turning when you put an adjustabloe wrench on the clutch, unscrew clutch to get other half of housing off to get to the pull rope.
Jun 06, 2010 | Craftsman 22" Gas Hedge Trimmer
It,s not getting spark
first try another plug but must make contact to metal not the aluminum head when checking you can remove the plug stick a screwdriver in the sparkplug boot and ground the shaft of the driver to something meatl on the unit and pull recoil few times fast watching for a spark. second thing is the coil is bad ,replace
Sep 03, 2009 | Craftsman 22" Gas Hedge Trimmer
Wont coil back into its housing, so trimmer wont start. Has compression though
Hi, this a cut&paste from elswhere but it applies to your problem:
how to repair a recoil spring: whats missing is this, you should always wgear eye protection when dealing with springs of any kind.
remember safty first. :)
Remove the recoil shroud and take a look at the assembly.
You might have a broken spring or just a rope that has slipped out of the reel.
The spring usually breaks at one of the end tabs. If so, you will need to get a replacement spring and carefully wind that in, before re-assembling the rope reel. You might wish to replace the rope also, if it shows signs
of wear.
You will need to remove the entire cooling shroud. There should be 4 bolts on the sides. You might need to remove the fuel tank also. Pre-wind the recoil reel by hand [about 6 turns, to set the spring tension] and clamp it with Vise-Grip pliers. Remove the old rope. Thread
the new rope through the shroud housing eyelet and to the reel hub. Let the reel re-wind itself until it is full. If there is not enough spring tension you can wind it a couple of turns more by slipping the rope around
between the reel and shroud. Re-clamp the reel. Cut the rope to length and thread it though the handle. At all knots, burn and melt the rope with a
lighter to prevent untying. Re-assemble.
(special thanks to "Micheal"the author)
May 19, 2009 | Poulan Pro 25hht 25cc 22" Gas Hedge...
How do I pull the clutch assembly to replace the pull rope?
remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, the starter assembly will need to be replaced.
Sep 13, 2008 | Craftsman 22" Gas Hedge Trimmer
Garden Logo
928 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
