Question about Kenmore Microwave Ovens
Microwave Model 87720 fuse location
Model 87750 fuse location
    Scholar:
  • 117 Answers
Almost all models have the fuse located under the control panel .Should come off with a couple of screws but careful with the ribbon. Hope this helps
Posted on Jul 30, 2009
Where do i locate the fuse
Although you have not mentioned the model/make, take a look at the video here for replacing a Thermal fuse. Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
on traditional fuse see
How to Fix Microwave Oven Simple Fuse Replacement
Mar 08, 2016 | GE Microwave Ovens
Where frigidaire microwave fuse located?
Good Afternoon Friend, that's a great question!
Depending on the model of your Frigidaire microwave, the fuses are typically on located behind the control console, on the magnetron or on the oven capacity. Hope this helps! - Z
Aug 03, 2014 | Frigidaire Microwave Ovens
Where are the fuses located on a samsung electric range oven FTQ3521WW model #
Hello
Fuses can be located behind the microwave door or behind a panel either on the interior wall or an exterior panel. Often the fuse will be behind a panel located under the louver vents on top of the microwave
Oct 04, 2011 | Microwave Ovens
Where is the fuse located on the sharp r-1875 microwave
you have to take off the external housing and you will see a glass fuse near the power source.
Jul 19, 2011 | Sharp R-1874 Convection/Microwave Oven
Where is the fuse located in a GE Spacemaker II microwave model number J EM824_ _ _ ? I can't read the rest of the model number.
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should begin working.
Feb 09, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
We have here below the link with the parts layout of your microwave
oven model. The fuse is part no 15 Line fuse
Part Number: AP3119665
made by WHIRLPOOL
Which as you can see is
located in the internal control parts area.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5168435&diagram_id=28370772#d28370772
Dec 19, 2010 | Magic Chef CMV1000B Microwave Oven
Where is the fuse located?
If the model number is correct, there is a small input line filter board with a 125V, 20 AMP line fuse inside the microwave. Its usually mounted on a small input line filter board at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line filter is listed as item 1420. The fuse will be mounted to this board.
You can purchase replacement fuses at any hardware store. You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Slow Blow fuses are recommended.
If you have any questions, or need assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit.
Apr 24, 2010 | GE JES1290 Convection/Microwave Oven
Micro wave simply quit. How an I check to see if
The fuse is located inside the microwave. You will need to remove the front panel to get to it. It will be located on the black power wire inside the microwave and installed inline. Make sure that the microwwave is unplugged before removing the front panel. Once you locate the fuse inside you will need to remove it and test it with a continuity tester to see if it is blown. If it is make sure you replace the fuse with the same amp rating you found. If the new fuse blows again then there is an electrical short somewhere inside the microwave.
Dec 24, 2009 | Emerson MW8778 Microwave Oven
AFTER 12 MONTHS ON NO PROBLEMS IT WONT WORK. IT DOESNT GIVE ME DISPLAY LIGHTS OR ANY.
most likely the internal fuse
be soooooooooo carefull in replacing this , the capacitor inside the machine can store a huge charge
  1. Turn off all electricity to the microwave and unplug from the wall socket. Move the unit to a well-lit location to better see the appliance.
  2. Step 2 Usea schematic for the particular model of microwave being worked on tolocate the area containing the fuse to be replaced. Fuses can belocated behind the microwave door or behind a panel either on theinterior wall or an exterior panel. Often the fuse will be behind apanel located under the louver vents on top of the microwave.
  3. Step 3 Removethe panel according to the manufacturer's instructions. Use a screwdriver to remove screws and set aside for replacement.
  4. Step 4 Locatethe blown fuse and check with a voltmeter. This step ensures that theproblem with the microwave is indeed a blown fuse and not anotherissue. Check for current between fuse connectors.
  5. Step 5 Take the blown fuse to a local hardware or store such as Lowe's or Home Depot. Staff can assist in finding the exact replacement fuse for the model being repaired.
  6. Step 6 Placethe new fuse into the panel in exactly the same fashion as the blownfuse came out. Replace any panel using the removed screws and returnthe unit back to its proper location.
  7. Step 7 Plugthe microwave into the wall socket and turn on all electricity. Testthe unit by ensuring the clock and all other features function.
Oct 21, 2009 | Emerson Microwave Ovens
Does the hotpoint microwave model # RVM1535DM1WW
Yes most of them do, take the outer casing off, should be located either were the power supply is or the control module is,
Aug 13, 2009 | Microwave Ovens
Microwave Ovens Logo
319 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
