Question about PfaFF Creative 7570
Pressure foot doesn't go down
After releasing the pressure foot lever the pressure foot does not go down against feed dogs
    Novelist:
  • 190 Answers
You can do this only if you're mechanically inclined. If not, find someone who you trust and give him/her these instructions. Good luck!
I own this machine and had the problem.
Needed tools:
Small flat screw driver.
Large Phillips screw driver
Small torx screw driver
Large torx screw driver
Small cleaning brush
Small scissors and long tweezers.
Machine oil.
Old tooth brush.
Dish detergent.
Lots of care and patience.
In this particular case, perseverance was the winner. I'm quite handy with mechanical things, so I had to partially disassemble the machine until I found the cause of the problem. The foot presser mechanism DOES have a spring, but it's concealed and out of sight. I never suspected it, but that was the case. When I found it, white grease that was put there at the factory to lubricate its movement had turned into a thik sticky gunk. That was what was holding the foot presser in the up position. This gunk was so stubborn! I had to clean the spring, the housing and a plastic pin really well, and then oiled all the components inside their housing. More below.
The shaft of the foot presser is hollow at the top. This is designed to hold a 1-5/8" spring and a 5/8" black plastic pin that's inserted at the top of the spring and protrudes from the hollow shaft.
Start placing the 7570 on a table that has a height that's comfortable for you. You'll be standing and squatting a lot to accomplish the task.
Standing behind the machine, and looking down, there's a metallic plate on your right that holds the thread tension discs. This plate covers the shaft, found underneath, and holds together the mechanism with the round wheel with numbers that protrudes slightly on the side of the machine's body.
Several pieces had to be disassembled in order to get to this plate, although at this point I'm doubting whether or not so much work was necessary, since I was so excited upon the discovery that I forgot to notice whether I could have found the spring and remove it without having to disassemble so many pieces.
The metal plate is black and thick, and is held down with a heavy gauge black machine screw. The plastic pin makes contact with the underside of this plate, which compresses the spring when the foot presser lever is up. Once the lever is disengaged from its locked or resting position (in the case of the embroidery position), the compressed spring pushes the entire foot presser down, as it DID when I first bought the machine.
These are the disassembly steps, without diagrams, but use your imagination as best you can to picture my description.
1 - Top cover removal.
The top cover (the one with the different built-in patterns drawn on its inside face) is held in place by two thin metal plates where it hinges. A little bit of pressure towards the outside on the top of one of the plates (on either side) will release the pivot pin on one end, and then a little jiggle in the same direction will release the other. Put the cover aside.
2 - Concave top cover removal.
This cover is the one that houses the thread spool in the horizontal position, if that is your choice when sewing. It is held down by two plated machine screws, one short and one long. After removing the screws a little jiggling will help removing it, pulling it mainly upwards. You may need to put the large handle up, to allow for more movement. Put it aside once removed.
3 - Side cover removal.
This is the cover on the left side of the machine, facing the buttons on the front of the machine, where the foot presser is housed.
Standing behind the machine, once step 2 has been achieved, one can see from the top, looking down, a large black machine screw on your right hand side, just inside the cover. You don't need to remove it completely, just about 1/2 turn will loosen the pressure to release the cover. Pull the cover outwards and sideways and set aside. You may want to also remove the light bulb, to be able to get to the mechanism to clean it, to remove pieces of thread that may be lying around or caught in the different moving parts. Push the light bulb gently in while turning it counter clockwise. You'll feel it disengaging from its socket. Pull it out and set it aside. Clean it if necessary. Use the scissors and the tweezers to remove any lint and debris.
4 - Pressure discs plate removal.
I'm not 100% sure now that this can be done at this stage, but continue. If this particular plate cannot be removed, because other components get in the way, then skip to step #4A below and come back here later.
Standing behind the machine, looking down at the housing, you'll see another large black machine screw holding down a black metal plate. Remove it completely and put it aside. Next, remove the plate, gently nudging its way out of the different obstacles that may be present. One of them may be the sewing mechanism. If this is the case, gently turn the wheel manually to cause the mechanism to move up or down, as to allow more room for the plate to be completely removed.
Make sure you lift this plate slowly, as to prevent the spring and plastic pin from spilling inside the machine's body. Put the plate aside. Now you see the black plastic pin, perhaps stuck inside the hollow part of the foot presser. If so, pry it loose gently and clean it with a sudsy solution, and use an old tood brush to remove the gunk from its coils. Do likewise to the plastic pin.
While you have the housing exposed with lots of space, I would suggest you should remove any debris, dust, etc, and oil all the moving parts with sewing machine oil.
5 - Assembly.
This is done in the reverse order. Congratulations! You've done it!
Additional steps, if metal plate in step 4 above cannot be removed after step 3.
4A - Front plate removal (The one with the colored buttons and LCD display)
Standing behind the machine, looking down, you'll see a grey ribbon cable crossing the case from back to front, under the main shaft. Remove its connector by pulling it up gently. No force or tools are necessary. Bend the ribbon and set it aside, out of the way.
Squatting a little from the same position, looking inside the foot presser housing, you'll see two small plated screws, close to the edge of the housing, one towards the top and another towards the bottom. Remove completely.
In the same squatting position, and moving your attention to the main machine housing, you'll see the green PCB board. It's held by at least three screws. One of them, on your extreme left, is not visible because it's concealed by a plastic insert at the top of the left end of the 7570. This insert is held down in place by a thin black metal plate. This plate has a tiny hole where the top cover of step 1 hinges.
Gently turn the small torx screw holding down this plate 1/2 turn counter clockwise to release the pressure. Once loosened, slide the plate slightly towards your right. This will allow you to pull the insert up.
With the insert out of the way, squatting again, you'll see the third plated screw on your left. Remove it.
Turn the machine upside down and ensure it's not rocking from side to side.
Use the large torx driver to remove the machine's base. This base contains a power supply box, and another green PCB board. It's connected to the rest of the machine with several ribbon cables of different colors. The base is attached by 4 machine screws. Loosen the screws completely and remove using the tweezers.
Raise the base from the right end, allowing its other end to rest on the edge of the inverted 7570 body and stand it at 90°. Inspect the location, orientation, and general layout of the cabling. You may need to unlatch one or more plastic holders for the ribbons, which hold them flat and organized.
Jot down the order of the different ribbons and the way the are inserted into their sockets on the PCB found inside the base. Fortunately the connectors are of different sizes, and there should be no way to insert the wrong one in the wrong socket, but it's best to be safe. Jot down order, orientation, etc.
Gently pull on the different ribbons from the PCB board. A little bit of force is all that is needed. Push them aside one by one in order to allow you to see more and create more space.
Next, disconnect the large power cord. You need to insert a small flat screw driver to release pressure on the sides of the socket. Do it one side at a time, and then gently pull it out. Set the base aside. You're almost done!
Next, looking down, pushing the ribbon cables away from you, you'll see two plated screws in each corner of the inverted 7570 housing, on the side closest to you. Remove completely. At this time you should be able to remove the face plate, gently threading the widest of the ribbon cables through the opening on your left, in order to put put the base aside.
With the face plate out of its position, put the machine in its straight up position and step 4 above can be accomplished.
Now, I also did remove the 7570 main handle in order to create more space and see more in the reduced area of the foot presser housing. If you too find it necessary to do so, use the corner of the tip of a small flat screw driver to pry the lock ring open, being careful not to allow it to spring out your fingers and falling inside the 7570's case. Slide the pin out and then the handle itself, in the opposite direction.
Go back to step 4 above if you came here because you could not do step 4.
Posted on Aug 21, 2009
  • 26 Answers
Needs to be serviced, you can ship to me i can fix keithat11@aol.com
Posted on Aug 06, 2009
My foot won't press down all the way
Make sure the feed dogs have been raised. Also, most machines have a presser foot "pressure adjustment" that increases or decreases the pressure applied to the feed dogs. Consult your owner's manual.
Also, check that you are using the correct presser foot shank for your machine.
Sewing Machine Feet
Could also be something amiss with the presser foot lever.
Apr 05, 2017 | Sewing Machines
Hi, My Elna 7000 doesn't easily feed medium or thin fabrics. Presser Foot tension lever is position 2 and the Feed Dog is rising normally. Any thoughts please? Does the F Dog wear out in any way?
Generally, the lighter the fabric weight, the heavier the presser foot pressure. Yes, feed dogs do wear with use. Do not run the machine without fabric between the presser foot and the feed dogs--the feed dogs constantly rubbing against the presser foot will quickly wear the feed dog points. Store the machine with the presser foot down with a pad between the presser foot and feed dogs (even a scrap piece of fabric will do). Also, be sure to clean the feed dogs of any gunky build-up. If the feed dog points are worn, it may be worthwhile to have them replaced.
Jan 23, 2017 | Elna Sewing Machines
My fabric won't feed
Check that the feed dogs have not been dropped for darning or free motion quilting. If the feed dogs do not rise above the needleplate, they will not pull the fabric through the machine.
Feed dogs do wear (which is why one should always sew with fabric against the feed dogs--never on bare metal).
Something else that happens is that gunk builds up between the teeth of the feed dogs so that they no longer have the grip they need to move the fabric.
Another thing to check is the presser foot "pressure." A lot of sewing machines have a pressure adjustment that increases or decreases the amount of pressure the presser foot applies to the fabric and feed dogs. (Consult your owners manual.) he pressure can be adjusted according to the type of fabric being sewn.
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
http://makeitsew.biz/presser-foot-pressure
Adjusting the presser foot pressure on your sewing machine
sewing patternreview com
Sep 04, 2016 | Sewing Machines
Not feeding material.
Tension generally does not affect the feed unless it is way too tight. Most reasons for fabric not advancing under the presser foot is that the feed dogs have been dropped for darning. If the feed dogs are operating properly, as the handwheel turns the feed dogs should rise above the plate, move toward the back of the machine pulling the fabric, drop down, come forward and rise again.
The other possibility is that the presser foot pressure has been released so the presser foot is not holding the fabric down on the feed dogs. Some machines have a spring-loaded knob on the top of the machine, a dial, or something to adjust the amount of pressure the foot applies. Consult your owner's manual.
Aug 10, 2015 | Sewing Machines
I don't think my pressure foot is down enough or maybe something is wrong with my feed dog, but I am able to move the fabric every-which-way while it is stitching, resulting in a crooked stitch line.
Without knowing the make and model, it's hard to say, but some machines have an adjustment to change the pressure being exerted on a presser foot. It is 'presser' foot, not pressure foot.
Some have some sort of knob on top, roughly in line with the needle that you either turn or push down.. some have a dial inside the side door with a few numbers on it, that may start at 0 and go to 3 or 4. If the pressure adjustment has become set at 0, then you get what's happening with yours, being able to pull the fabric like you can.
If there isn't any knob or dial to change the pressure, then it may be the feed dogs need adjustment or the bar that the needle and presser foot are attached to needs adjustment, and that wouldn't likely be a fix you can do yourself unless you are very handy with mechanical things.
Some machines also have a lever or switch that allows the feed dogs to be lowered out of the way. If yours has this, it may be stuck in a position below being all the way up, and that might be the issue. A feed dog switch is usually at the front of a machine, low down, not too far from the feed dogs.. but without knowing what machine, hard to say where it might be exactly. But check for both these things.
Nov 19, 2014 | Sewing Machines
Why is My fabric is not feeding through the pressure foot
the feed dogs are what move the fabric under the presser foot so the needle can sew. check your instruction manual and see where the lever is that operates the feed dogs. if the lever is up then the feed dogs will feed the fabric, if the lever is down, then the fabric will stay in place. if the lever is up and the feed dogs are not working, then it's time to have them checked.
Jun 10, 2014 | Husqvarna Huskylock Computerized 905
Does 514 pressure foot move?
what is the name of the machine?
do you want a manual?
the feed dogs are what move the fabric thru the machine, the presser foot only hold the fabric against the feed dogs so the feed dogs can move the fabric
the feed dogs in the needle plate area should be up
May 28, 2012 | Sewing Machines
Pfaff 6091 Presser foot won't go all the way down
HAVE THE 6091 MACHINE AND THE FOOT IS NOT FROZEN BUT WON'T GO DOWN. OILING THE MACHINE DID NOT HELP AT ALL. HAD A REPAIR MAN COME TO THE HOME AND CLEAN THE MACHINE. STILL THE FOOT WILL NOT GO DOWN.
Nov 21, 2011 | Sewing Machines
What does feed dog lever do on my Elna 6005 Heirloom sewing machine? Do I need to alter it for sewing very thick fabrics/seams?
Feed dog lever should lower the feed dogs, these are the teeth that grip and move the fabric foward and backwards as the needle goes up and down, they are under the needle plate.
Only time you would lower the feed dogs is if you want to do free motion embroidery or darning perhaps.
So no, don't touch for normal seam stitching. If you are sewing very heavy fabric you may want to lessen the pressure on the presser foot a little (if your machine has this adjustment it will be a knob on top of the head above the pressure foot area).
You may find that your machine doesn't really like very thick fabrics. Sewing something like upholstery weight with a domestic machine is pretty ambitious; an industrial strength machine is best bet.
Nov 09, 2011 | Elna Heirloom Edition 6005
Hi the pressure foot in my toyota RS2000 does not move when i try to sew. What could be the problem
check the feed dogs that are under the needle plate to see if there up or down,, if they are up you can feel them when you slide your finger over them,, only if there up can the machine sew,
the pressure foot holds the fabric against the feed dogs & the feed dogs move the fabric
Aug 26, 2011 | Toyota STF39 Mechanical Sewing Machine
Sewing Machines Logo
369 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
