Ive put some burnt music files onto my sansa which appear as unknown album but wont plathe sansa flicks onto them and then directly back after selected
You must enter the folder your downloaded song folder into media player libary, then sync start sync list, select all music. they will come up select what songs you want on your player then start sync, watch then download....You must enter the folder your downloaded song folder into media player libary, then sync start sync list, select all music. they will come up select what songs you want on your player then start sync, watch then download....
You can't post conmments that contain an email address.
Hi, the Sansa E260 is a portable MP3 player released by SanDisk in 2004. Several problems may cause the E260 to not function as intended from time to time. Common problems that occur are the device freezing, album art not appearing on the screen when a song is playing, pictures not filling the screen size and missing information on the separate tracks. You can troubleshoot the device and fix many of these common problems without the need of a service technician.
Reset 1. The Sansa E260 may freeze or function in other unexpected ways from time to time. This generally occurs when the unit's software has developed an error. Reset the device to clear the error and return the device to normal working operation. A unit reset is similar to rebooting your computer. You won't lose any data stored on your device.
To reset the E260, press and hold the "Power/Menu" button for about 15 seconds. The device will be forced to power down, during which the error will be cleared. You can restart the E260 as normal once the reset is complete. Album Art Does Not Display 2. The E260 supports viewing album art on the display screen during the playing of a song. You may find that your album art is not showing up on the display when music is playing on the device. To fix this, make sure the associated album art file is in the same folder as the song being played. You will need to connect the E260 into your computer to move the album art files into the music folder. Photos Aren't Full-Screen 3. Photos displayed on the E260 will not show up as full-screen shots if they are not cropped to the correct dimensions. The E260 software does not support stretching pictures to fit the full screen. To ensure your photographs will display on the full screen, crop the images to 128x64 in photo-editing software prior to transferring the image on the E260. Unknown Artist or Album 4. The E260 displays information about each song using the ID3 tags associated with each track. ID3 tags hold information such as the artist name, album name, track number, year it was released and other information. If the E260 shows an artist or album as unknown, the information in the ID3 tag was not filled in. You can insert information into the ID3 tags from your computer.
To change the ID3 information, right-click on the music file and choose "Properties." Click on the "Summary" tab and choose "Advanced." The ID3 fields will display in the window. Insert any of the missing information and click "OK." When you upload the song onto your E260, the newly inserted information will show up in the display.
Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete Labeling Unknown Songs: open Windows Media Player and go to library click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then sync with your sansa or media player then load songs to it........
Labeling Unkown Songs: open Windows Media Player and go to libary click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then syc with your sansa or media player then load songs to it........
1) You need to set the "tags" in the music files ... artist, album and song name. I would suggest opening up the files in MediaMonkey, which will let you edit the tags.
2) After you download the podcasts with MediaMonkey, you need to find out where they exist on your disk. Then, copy them to your Clip using Windows Explorer.
open windows media player and goto libary click on album artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... then syc with your sansa then load songs to it........
You can put music on it by doing the following (assuming vista/XP environment):
Connect it to your PC using the provided USB cable. Open windows explorer and navigate to your Sansa Clip. Click through "sansa clip", "internal memory" to the "music" directory. Drag and drop MP3/wav files to this directory. Feel free to create subdirectories. Your music will be accessible after doing this. Be aware that the clip ignores your directories. It will look for artist, album, and title tags to categorize your tracks. You may have to look for your tracks in the "unknown" album directory when playing if your tracks don't have these (ID3?) tags.
I want to know how to put my limewire mp3 downloads on my sansa e260
