Question about Canon SELPHY CP740 InkJet Photo Printer
Question Mark Appearing on Canon Selphy printer screen
I placed my SD card in the spot on the Canon printer and a big question mark appears on the screen of the canon selphy! I've used this plenty of times and have always done it the same way. I even tried connecting it to my computer. Can anyone help?
I encountered this issue with a Selphy CP800 and I presume the reason is the same; it seems to be a common problem. Canon tech support says that Selphy printers need exif data "just so" in order to generate screen previews. If all you do is copy your image to a flash memory device from your camera card, you may well be OK. But if you edit the images (e.g. in Photoshop) you will very likely alter the exif data so that Selphy cannot generate previews from flash media plugged into Selphy. If you are copying images back to a **camera** SD card you may also have to make sure that you don't alter the file structure already present on the card. There are undoubtedly other ways to louse up the exif data of an image so that you can't get a screen preview. Workarounds: 1) official Canon advice is to print the image directly from your computer - that's what tech support told me; 2) if you own Canon's Digital Photo Professional Software you can rebuild the exif data by using File>Convert and save>kind of file = exif-jpeg - this worked for me; 3) Graphic Converter for Mac now has a way of rebuilding exif data according to a poster on the Apple discussion boards; I could not test this out b/c my (old) version of Graphic Converter, 5.4, does not have this capability; 4) if you get a screen question mark, the image will still print - you just can't see the preview. This is only a problem if there's more than one image that generates a question mark on your flash media device because you can't see what image you're printing. So if all else fails and you have to print from flash media, you can put a single image with screwy exif data on a flash drive and be confident that you know what you're printing.
Posted on Mar 28, 2012
This just happened to me... I finally figured out a solution... hope it works for you too.
First I put the pictures on my computer. Then I erased everything on my SD card. Then I dragged the photo file from the "My Pictures" on my computer hard drive to my SD Card - make sure you don't put it in a file folder on the SD Card (that was my mistake) Good Luck!
Posted on Apr 22, 2010
  • 130 Answers
It sound like the sd card slot is bad.you might try putting sd in and reboot the printer
Posted on Jul 30, 2009
Ink appearing on the back side of pages prints
This is called duplex printing or two sided printing. If you want to disable it, you can go to
Start>Devices and Printers>Right Click on your default printer>Select printer properties>Click on the box where the check mark appears in the box "duplex printing." This will remove the check mark. Click ok.
Apr 17, 2011 | Canon MP830 All-In-One Printer
I have a usb with my photos on it...an i want to print them using my canon selphy cp760 compact photo printer but when i put in my usb it says "usb device not supported" and wont allow me to see...
you may have the higher capacity sd card, you will need to buy the usb dongle that supports the larger capacity chips. they are about 8 to 10 dollars US. If you have a card slot on your computer, you could try putting your SD card in there and that might work.
Mar 18, 2011 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Canon selphy cp780 when i insert memory card a question mark comes onto screen and doesnt recognise any photos the photos are in jpeg i am using a compatible memory card
Are you able to upload the photos to your PC?
If so, transfer them to your PC then format the memory card using your camera or PC, then download the photos back to the memory stick & insert once more into your printer.
Let me know if this procedure resolves the issue.
Best wishes,
Graeme.
Mar 12, 2011 | Canon Office Equipment & Supplies
No display on the printer screen when i insert
Check the specifications for the printer. It may not be able to accept the SDHC cards which speak a slightly different language than SD cards and most older devices will not acccept them. Any sd or 1gb or small card will work fine.
Mar 01, 2010 | Cameras
Selphy ES1 printer switches on,
remove all the connection go to control pannel printer and default ur Selphy Es1 printer
Jun 18, 2009 | Canon SELPHY ES1 Thermal Printer
Canon SELPHY CP740 InkJet Photo Printer Logo
6,236 people viewed this question
old marine
old marine
