DC power jack on a Fujitsu N6420
I need to replace the DC power jack on my Fujitsu N6420 laptop. I know how to open the latop and make the physical repair, but I don'd knwo what replacement part I need to complete the repair. Any ideas?
  • 23 Answers
Have you opened up the laptop? Online it looks like this jack isn't actually attached to the motherboard judging from this posting:
http://cgi.ebay.com/Fujitsu-LifeBook-N6410-N6420-DC-IN-Jack-CP236954_W0QQitemZ110413931875QQcmdZViewItemQQptZPCA_Cables_Adapters?hash=item19b52ee563&_trksid=p3286.m20.l1116
I usually go to Laptop Jacks but couldn't find your model of laptop. Usually you can call them and they will send you out the right jack.
Posted on Jul 30, 2009
  • 130 Answers
You can try take apart but when i did it was a night mare.i say take to shop.if it was a desktop i say you could fix it easy,but a laptop
take spacily tools to do it right
Amilio laptop not charging in spite of new charger
please measure the output for your charger,normally they have 19.5 vdc exactly, if they do not measure the adapter is faulty, repair or replace.If the output is o.k the battery can be faulty. Use the software diagnostic coming with the computer, restart the computer HOLD the key f2 or esc depending of your computer model, and make the diagnostic.try again and see what is the result, if the battery is o.k or faulty.God bless you
Apr 05, 2013 | Fujitsu Computers & Internet
Hello, power failur on mother board p/n cp298380-01
So how is the DC Power Jack solder joints on that Fujitsu Lifebook?
The DC Power Jack (DC IN) is the jack on the laptop where the AC adapter (Charger) plugs into.
Do any of them look oxidized?
Dull finish on any of the solder joints holding the DC Power Jack to the motherboard.
De-solder and makes fresh solder joints.
Are any of the solder joints cracked?
Cracked at the area of the solder joints to the bottom of the motherboard.
Re-solder.
What condition is the DC Power Jack itself?
Physical condition of the jack.
Bad physical condition requires replacing.
Do you see any discoloration, or burn spots on the chips on the motherboard?
(I.C., Integrated Circuit = Chip and Chipset)
There is a sensor chip on the motherboard for power. Senses when the battery needs to be charged, or doesn't, and when the laptop is to just use the AC adapter power.
If so replace the motherboard.
Post any questions about the above in a Comment.
(Believe upper right of your page > Comment)
Regards,
joecoolvette
Dec 02, 2010 | Computers & Internet
Where i can buy, power socket for my amilo pro v2010?
Just one example,
http://www.laptopjacks.com/view_part/For-Fujitsu-Amilo-Pro-V2010-DC-Power-Jack-FJ41420.html
The power socket in the laptop that the AC adapter (Charger) plugs into is a DC Power Jack.
Type Amilio Pro V2010 DC Power Jack in your browser search bar, press the Enter key.
To add:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Nov 07, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
My fujitsu A3130 screen doesnt turn on. the only thing it does is that the 3 lights in the top right corner turn on and off.
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 15, 2010 | Fujitsu LifeBook A3130 Notebook
How do I replace fujitsu 2727 power socket
Get it fixed by going to jackfix.com , replacing the dc power jack requires taking apart the entire laptop, then removing the motherboard, and finally desoldering the power socket, and resoldering the new jack, and putting everything back together, its no job for a beginner. Not being rude at all, but if you have to ask how, dont attempt. http://www.jackfix.com , they have replaced many power jacks for my laptops, as well as my companies, they give a lifetime warranty, and will ship the laptop back to you within 24hrs. believe me, I have tried different companies, and they are def best.
May 11, 2010 | Fujitsu AMILO PC Laptops
NO sound
Find a driver for your system
Jun 17, 2009 | Fujitsu LifeBook® N6420 PC Notebook
Toshiba Satellite 1415-S173
Hi
DC jack replacement is easy however requires a bit care since its mounted on the mainboard. Desolder the old DC jack. Solder the new one firmly. Dont keep the soldering iron too long on the PCB as it will damage the lines and will deform the DC Jack. You can get DC jack very low cos from local repair stores or you can order from Toshiba parts depot (800-524-8338)
Please post your question if you need further assistance.
Good Luck
Feb 09, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu S6120 laptop power problem
I fixed my S6210 wen the poorly designed connector broke. Fujitsu wanted $ 250 to do the job. The part is only $ 5. I also bought a Cable Retention Device to keep from jerking on the cable.
Here's a video that talks about the problem and the cure.. . .
Jan 08, 2007 | Fujitsu S6120D PC Notebook
Computers & Internet Logo
347 people viewed this question
David Payne
David Payne
