Question about Hunter Ceiling Fan Control Switch
Ceiling fan Hunter fan w/ remote control will not work. The battery is operational in the remote control, however the fan nor light will operate. Any suggestions as to why this may be. Thanks!
  • vanryswyk May 06, 2008
    The remote's red light comes on, but it will not operate the fan.
Hi you have a problem with your fan do you have the remot book how to operate the fan remote we lost the booklet for the instruction maybe you can send me a copy of your booklet instruction for the fan is your fan is from the compagny home collection and the brend or model tampa thank you
Posted on Nov 25, 2007
Hunter Ceiling fan remote will only work for the light. It will not work for the fan. I have paired it.
  • Disconnect power at the source
  • Remove batteries from the remote and press buttons to be sure none are stuck. Reinstall batteries
  • Reconnect power and test operation
If you are using wall switches in addition to the remote, decide how you want to control fan and lights and don't confuse things.
Apr 04, 2017 | Hunter Dryers
Set up remote on harbor breeze
Check the frequency on the receiver & transmitter to make sure they match.
Mar 29, 2013 | Hunter 52" Ceiling Fan With Light And...
Is there a way to take remote controll off of a fan mine stoped working after kids pulled fan or light pull
My ceiling fan loses remote control every time there is a power outage. The first thing to do is turn off power to the fan at the circuit breaker. Take the battery out of the remote and push all the buttons to eliminate a stuck button as a possible cause. Reinstall the battery. Turn on power to the fan. Check operation. You may have to pull a chain to "reeducate" the remote but you should be back up and running soon.
Dec 31, 2012 | Hunter 52" Ceiling Fan With Light And...
Hunter Ceiling fan remote is operating all the other ceiling fans as well
Sounds like all the dip switches are set to factory still. Easy enough to fix.
Slide open the battery compartment on the back of the remote control and remove the fan's canopy against the ceiling. Then just change the switch to a different setting but make sure that the remote and fan have the same setting. Repeat this in each room so that all the fans have a different setting to each other.
Hope this makes sense.
Aug 02, 2012 | Hunter 52" Ceiling Fan With Light And...
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Jun 20, 2009 | Hunter Ceiling Fan Remote Receiver...
Hunter ceiling fan remote control will not work
Are you talking about just activating the fan, or the tv as well? If you just need the fan, in the top plate where your fan is mounted into the ceiling, there is a box. This box has 4 switches that are turned on or off towards a number. You find that and then just open your remote up and set the switches in the remote to the identical numbers. I need help for the tv codes i lost the booklet, i need the codes for a daewoo.
Apr 26, 2009 | Hunter 20537 / 20538 The Vista Iron...
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Dryers Logo
322 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
