Question about Maytag Portable Air Conditioner M6P09S2A
Doesnt cool small bedroom with doors shut. I have
Doesnt cool small bedroom with doors shut. I have it set for 68 degrees but it doesnt cool past 83. Is there an easy fix?
  • 867 Answers
It should freeze that room with 9000btu do you hear the compressor turning on or is it blowing jus air? also helps if you switch the air intake to recirculate the room air rather than intaking the air from outside
Posted on Jul 30, 2009
I have my brand new frigidaire window ac unit set at 60 degrees Fahrenheit, so why does it only cool and keep the room at 65 to 68 degrees Fahrenheit?
if you have it set at 60 F and it is working at 65 to 68 F then that would be about right
as the air is cooled the cold air falls to the floor and out under the door, open window or anywhere else it can escape
the unit has to be at 80% room height so if it is set in a window then when the cold air gets up to the thermostat or ac level in the window then it will stop cooling
So if the ac unit is say 4ft from the floor and the ceiling height is 8 ft then the ac will only cool the bottom 4 ft
cold air does not rise but falls down
if you are using a ceiling fan then the cold air is stirred up and the 65F sounds about right
remember that the setting temp ( what you set it at) is the lowest temp that it will go down to before it stops cooling and if that is not reached it will keep working to attain that temp and if the room is too big, air leaks under door . around the fit in the window , no insulated walls , hot exterior wall,etc then maybe 65 F is the best you will get
May 09, 2016 | Frigidaire Heating & Cooling
Thermostat set at 72 degrees on auto cool setting
Check the tstat's for a relative humidity setting. If it has that option set it to 60 percent. If not, make sure to check all programs if it's programmable. If not those 2 options, it may need to be replaced.
Oct 21, 2017 | Heating & Cooling
I have a Goodman CKL24-1k air conditioner. I live in a townhouse in Louisiana on the 2nd and 3rd floors. I set the temperature to about 73 degrees during the day so I can sleep bc I work the graveyard...
I lost you at my the end but the 2 ton unit should be able to cool 960 sqft. Sounds like a refrigerant problem. Air conditioners should cool the air 15 to 20 degrees. This means 80 degrees going into the machine in the return should be 60 to 65 degrees coming out in the supply. If you are in that range than it's likely never going to cool the space.
Jul 07, 2017 | Goodman Heating & Cooling
FAC122P1A I have a small 2 bedroom apt. maybe 700sq. ft. with bedroom doors closed the unit isnt cooling apt. as well as it did even a couple of weeks ago. The unit is blowing cool air but not enough to...
This unit probably need to be cleaned. Im in St. louis MO and its above 100 degrees with a heat index of 116 if your area is experiencing this kind of heat as we are there may be nothing wrong at all A/C units are designed up to 95 degrees when it get hotter than that the units never shut off till night fall.
Jul 21, 2011 | Carrier YC273D Air Conditioner Window/Wall
Indoor temp doesnt go to my punched in setting of 68 on therm
if it is around 93-97 degrees outside,thats all the cool your going to get
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
Need to know what the settings are for the range adjustment A,B,C,D slide switch on the front panel on a Amana PTH123A35AC PTAC
Here they are;
Position A, Cool 70-78, Heat 65-73
Position B, Cool 68-81, Heat 68-76
Position C, Cool 66-83, Heat 61-78
Position D, Cool 63-88, Heat 58-83
Amana calls this a Temerature Limiter and says to only set one switch on at a time. If all switches are off then the unit is at full operating range.
Please rate this answer to let me know if it was the fix.
Jan 25, 2009 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
426 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
