Question about Ricoh Aficio 2015 Copier
Code sc 305
Same code, how do I clear it?
"charge corona cleaning error" ? - need more input :-) What does this mean, can I take something out and clean it? Obviously no budget for service person here....
  • paulhaak Jul 30, 2009
    ricoh aficio 1224c
  • paulhaak Jul 31, 2009
    thank you, we took the part out and cleaned it... so far so good. no error code now!
  • 313 Answers
You could try and reset in service mode yourself.. try this press the yellow clear button above the number pad then enter 107 then hold down the stop button for about 5 secs .. the screen will change then turn off the machine and wait 5 secs turn back on.. Im not sure why you are getting teh code 305 as this machine doesnt have a corona wire cleaner.. is the code correct?.. good luck
Posted on Jul 30, 2009
  • Andy Bell
    Andy Bell Jul 31, 2009
    Sorry missed the link back if its the 1224 then the connection on the charge grid down at bottm left of the pcu is either disconnected or faulty it looks like a lj 45 phone connector and the port is to the top right under the handle for pcu.. you coulld also take the coroner unit out and clean the grid with some soft brush there is a screw which holds ot down in place its usualy plastic on theese so dont loose it th wire can be cleaned with a bit of scotch bright but do this gently you might see a build up of toner on there as its under the cleaning unit for the drum cleaner and the devs drop toner on it as well.. once you have cleaned it make sure it sits back in proerly and if you need to reset the code do the clear 107 then hold the stop till sp mode show and you need to go to mode.5 then 810 for sc reset.. goood luck A
How to solve this problem sc 302
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
Sep 25, 2014 | Ricoh Office Equipment & Supplies
Sc 305 dsc 224
The error code sc 305 is a charge corona wire cleaner error. Has the pcu or charge corona assy been replaced or removed for any reason?
Oct 26, 2013 | Ricoh Aficio 1035 Copier
Error code E000069-0000
Error code E000069-0000: "corona transfer error"
This is an error regarding a problem with the transfer corona, it seems you had a high voltage spike on your machine, causing this error.
There are different causes for these errors, one of the most common is the dirt on the transfer corona to become operational will provoke "jumper" between the contacts.
What you can do is to spray air above the corona to remove the toner accumulatedand if the fault still need to clean more thoroughly.
Note: The corona tends at times to fail randomly.
Apr 30, 2012 | Canon imageRUNNER 7200 Copier
Code erreure sc 300 aficio mp 6000
SC 300 Charge corona error - charge corona power pack defective
SC 300 Charge corona error - charge corona receptical defective
SC 300 Charge corona error - charge corona unit defective
SC 300 Charge corona error - replace corona unit and enblock as set
SC 300 Charge corona error - replace Transfer Belt
Replace charge wire and grid or charge assy B2472010 -Carl
Jan 17, 2012 | Ricoh Aficio 120 Copier
Sc 220 and sc 305
sc220 means laser synchronizing detector board, (used to determine the start timing of laser writing), does not send asignal while the polygon motor operates normally and the LD
mirror in laser may be stink clean it carfully and clean small board synchro which detect invisible laser beam
sc 305 means pcr primary charge roller did'nt work correctly that means did't give sufficient charge to drum unit possible causes pcr defective
Feb 08, 2011 | Ricoh Aficio 1224C Black and White Copier
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
Sc300 had this code on afico 1075
Charge corona output error 1
The feedback voltage from the charge corona unit is too high
Possible causes -
· Charge P.P. defective
· Poor charge corona unit connection
Jan 25, 2010 | Office Equipment & Supplies
What does the Functional Code SC 302 involve? Thank You! Jacque
This code refer to main charge.The charge corona leakage.Check the charge corone wire and grid (clean or change),clean the corona unit input contacts,check the main charge power pack and the high voltage control board.Recomand to change the corona holders,wire and grid.To reset the error code Turn OFF the power switch unplugged wait 10 sec plugged and turn ON the switch.
Sep 23, 2009 | Ricoh Office Equipment & Supplies
KM Bizhub Pro 920 gets an error: SC21-04.
Wire cleaning problem, there are several motors in the copier that have the job of cleaning Very HighVoltage Drum Charge Wires and Image Transfer and seperation High Voltage wire The wires have a corona (Not beer:)) form on them and need to be cleaned.
Mar 25, 2009 | Konica Minolta Office Equipment & Supplies
Ricoh Aficio 2015 Copier Logo
320 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
