Ia unable to find why the tv is skipping from channel 2 -9leaving us unable to view 3Is ther a possible transmitter fault
Try having the TV tuner run the process of re- indexing / re- discovering the channels
That should immediately tell you if the receiver is having a problem
If it cant connect to known good channels then there may be a failure on one of the boards
Othwise that should fix the problem and allow access to the skipped channels
SOURCE: magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
SOURCE: cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
SOURCE: sony bravia-unable to tune in video channel via dvd
thethe wires have to run out of your cable box into the dvd recorder then back out to the tv,try rehooking it up
SOURCE: Philips 27S300 C101 TV. How do I program the
use this user manual because you will continue to get some problems with your TV. print this use manual;
http://www.p4c.philips.com/files/2/27pt643r/27pt643r_dfu_aen.pdf
