Bushnell Deep Space 78-9512  Telescope
Problem for Bushnell Deep Space 78-9512 (120 x 60mm) Telescope
Can not seem to focus when we look through the
By bryant2 on Jul 30, 2009
can not seem to focus when we look through the lens we just see the bk=lack sky we cannot seem to see anything
Best Solution
posted on Jul 31, 2009
Very Helpful)
khorianne5
Rank: Guru
Rating: 89%, 79 votes
try this:
see the mini scope on top of the telescope?--that's called the finder scope--
you look through that to see what the telescope is aimed at, just like what a sniper does before he pulls the trigger.
put in the lowest power eyepiece you have in the telescope, the one with a high number on it.
it's a good idea to align the 'finder' with the telescope during the day time--it's much easier.
if your telescope and finder scope aren't aligned properly, aiming your telescope at any target will be off and you'll just get frustrated.
to do this, look through your finder scope and pick a far away target, put in the lowest power eyepiece you have, that's the one with a high number--
high number = low power = a nice big view in the telescope.
low number on eyepiece = high magnification, like a zoom lens.
always use the lowest eyepiece first, then work your way to higher magnification, if you want to get a closer look at your target.
use lowest power eyepiece in telescope--> look through finder scope -->focus the image--> switch to higher power of eyepiece for a closer look at your target.
practice this during the day until you're comfortable, then try it at night.
try the moon, it's a nice big target
you can also use binoculars to check out the night sky.
you can try using 7x35 or 7x50 binoculars.
you see a lot more stars and it gives nice big views of the stars and constellations...and the moon...
hope this helps :D
Comments:
Aug 02, 2009
- whoops! forgot to mention how to align the finder scope.
there should be adjusting screws on the finder scope.
look through the telescope and make sure your target is centered in the telescope, then use the adjusting screw on the finder scope to match what you see in the telescope. make sure it's also centered in the finder scope.
hope this helps :D
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Bushnell Deep Space 78-9512
Questions and Unsolved Problems for Bushnell Deep Space 78-9512
Do you recommend Bushnell Deep Space 78-9512 (120 x 60mm) Telescope?
Answer
Answer
i have a micronta electric powered zoom telescope 12x-40x-40mm cat. no. 66-203 ----- electric does... (More)
Answer
What is the voltage and battery number for a Tasco red dot Propoint PDP2
Answer
What is the voltage and number of the battery for a Tasco red dot Propoint PDP2
Answer
just dont know who to ask? Blazer 3-9x50 Matte C/P it was shooting 2&half inches low at 25... (More)
Answer
Does any one still carry parts?I need the main piece that you use to view with.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bushnell Deep Space 78-9512 ...:
Top Telescope Experts
Rank: Guru Guru
Solutions: 3902
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Telescope Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
