Question about Samsung S7330 Cell Phone
Same i have the same issue with my samsung m7500 i had tried your settings as well to no avail. please post up if you are able to find the right internet settings. thanks!
How to hard reset Samsung m7500....
Power the phone on. The phone should go through the basic start-up and come to rest on the main screen. Press the "Menu" button and find the "Settings" option, then "Reset Settings." You may have a "Restore Factory Settings" option here, or a more extensive menu that lets you choose what to reset, such as sound settings, display settings, phone settings or all. Reset the phone by choosing "All" or "Restore Factory Settings." Press the "Yes" button when the phone asks you to confirm that you want to reset it. Power cycle the phone, and when it comes back on you will be able to reconfigure your settings correctly. That is it.
Jul 10, 2011 | Samsung Computers & Internet
MT SAMSUNG STAR GIVES ME A 'UNEXPECTED ERROR'
did you activated any gprs plan? Try to connect in some other area so that we can know is it settings problem or network issue.
Jul 23, 2010 | Samsung Star GT-S5233 Cell Phone
I just bought it on e bay and they must have used a password
I would contact the seller and ask them for the password, if they advertised it to be in good working order then you have rights to return the phone due item not as described. otherwise you will have to take it to a mobile phone repair center to be unlocked. Dan
Feb 17, 2010 | Samsung SGH-M7500 EMPORIO ARMANI Cell...
Need unlock codes for samsung M7500
You can get the unlock code here http://www.mobileunlocksolutions.com...-phone/rs1wp2/ and also get the unlock instruction in the same site....
Jan 30, 2010 | Samsung SGH-M7500 EMPORIO ARMANI Cell...
Keep lossing signal to my router have a netgear router wgr614
To resolve the issue, please perform the steps below to change wireless channel on the router:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open the browser(Internet Explorer or Mozilla Firefox).
3. Access the router (http://www.routerlogin.com).
4. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive).
Please try the following settings on the router:
1. Click on wireless settings (under setup) from left menu.
2. Change the channel to 07. You may try other channels in the list to check which ever suits your environment the best. you may try 01,03,06,09,11
3. Apply settings to save the changes.
I hope the steps above will help resolve the issue. If you need any further help, please email us back so that we can continue to work on a solution.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 21, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
How do I set up ATT Internet connection in the United States?
at&t does not sell the M7500. You will most likely have to input the browser,mms and possibly the sms settings manually. If you go to www.wireless.att.com ,click support and choose a model close to what you have, you will next be taken to a page with a link to tutorials. Use the browser settings tutorial for internet,mms settings for picture messaging and so on. You need to have internet to send the pictures.
Sep 01, 2009 | Samsung SGH-M7500 EMPORIO ARMANI Cell...
Check icon stays on, and never shuts off
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Aug 15, 2009 | NetGear WGR614 Wireless Router
My tablet isn't installed, so I have to set up my programs, but when I tried to get internet access, my tablet won't connect-on the bottom right side of the computer says that the internet is connected,...
Link here to troubleshoot internet explorer.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 16, 2009 | Computers & Internet
Samsung S7330 Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
