Question about Car Audio & Video
I just bot Pioneer speaker CH26861...4 wires to 2 leads...
I just bot Pioneer speaker CH26861 in-dash for my '68 Chevelle with 4 wires (2 each speaker) - but, my radio is original AM with only 2 leads (+ and -) into the back of the radio. So, do I split the speaker wires up and try to wire the 2 speakers in series?
I didn't get any instructions or wiring diagrams. I don't know which lead on each speaker is + or -, perhaps it doesn't matter? My thought is to run one wire from 'radio hot' to the far left speaker lead; then run a wire from the other lead on that speaker to the inside lead on the other speaker; then run a 3rd wire from the outside lead on speaker #2 down to the negative lead on the radio?
  • fred878 Jul 30, 2009
    Thanks for your feedback! the new speakers are 4 ohms each, and i'm guessing my original 68 radio is 4 ohms or 8. Question / clarification...at Basic Car Audio Electronics (BCAE1.com), they say 'series' wiring doubles the ohm protection from 4 to 8 - right?
    If so, my plan was to follow their diagram, with one wire from pos radio to pos speaker; one wire neg from that speaker to pos to the other speaker; and one wire neg on the other speaker back down to neg on radio...right?
  • fred878 Jul 31, 2009
    Hello Flagcar! Thanks a lot for helping me here, i'm really new at this. I keep reading I'll fry the amp in the radio if i do it wrong. Finally i see that if i go parallel and drop the impedance from 4 ohms per speaker to 2 ohms "net", i raise the power and clarity of the speakers.
    However, i apologize all over the place...i FINALLY actually took a LOOK at my 68 Chevelle Delco radio, and it's stamped on the back "wire speakers to minimum 8-10 ohms".
    Ohms Law says if you wire in series, you double the ohms impedance (in this case, 2 speakers). So i actually should have bot 2- 8 ohm speakers and wired them in parallel as you said. Now wiring them series to get 4 ohms each speaker to 8, i have to wire series, and this will lower my power and speaker clarity unfortunately.
    It's tought to learn the hard-way!
    Genius:
  • 1,114 Answers
If you state what the impedance rating (ohms?) of each speaker is, it would be helpful, but to be on the safe side, I suggest you hook up the speakers in parallel (+ to +; -- to --) .
The car radio is probably for a 4 ohm speaker (most car radios are)
If the pioneers are 4 ohms each, and you place them in series, the amp (radio) will see 2 ohms. That's not a good match for radio or speakers.
To determine which terminal on a speaker is positive and which is negative, follow this simple procedure (I've done this procedure countless times)
You'll need to be able to see the cones of the speakers.
Take a 1 1/2 volt battery (flashlight battery, size C, AA,D; the size doesn't matter - just 1 1/2 volt)
Take the wires from the speaker and connect to battery just momentarily and watch the travel of the cone.
If the cone moves outward - then the wire on the battery + terminal is connected to the speaker + terminal. So you have identified the speaker + terminal.
If the cone moves inward, then the battery + is connected to the speaker -- terminal, so the other speaker terminal is the +.
TRY IT ITS COOL!
Posted on Jul 30, 2009
  • 434 Answers
I would tie both + from the speakers to the radio, and both - as well. This will give an equal amount of power to both speakers and reduce the chance of blowing a speaker. As for +&- on the speakers, It is usually marked on the black piece right by the terminals. As little power as you are putting to the speakers, it doesn't really matter which way you hook them up, as long as they are both hooked up the same.
  • Mike Phillippi Jul 31, 2009
    wiring the speakers in series actually lowers the resistance from 4 ohms to 2 ohms. Wiring in parallel gives you 4 ohms per speaker, or 8 ohms total resistance.
What year is this engine? and ci
From this chart - I think you may be misreading the number - 3970010 is possibly the actual number: Which makes the engine pretty old 68-72 350 V8 - 4 bolt main. I included past this number so that you can see that the number you posted doesn't actually exist. And thus my conclusion that the 9 is most likely a 0. Hope this helps. 3970010 350 69 Corvette late 69,4 bolt main 3970010 302 69 Camaro Z/28,Late 69, 4 bolt main 3970010 350 69-79 Truck 2&4 bolt main 3970010 350 69-79 Pass,Chevelle,Camaro,Nova,MonteCarlo 2&4 bolt main 3970010 350 70 Corvette 300,350,370 HP 4 bolt main 3970010 350 71 Corvette 270,330 HP 4 bolt main 3970010 350 72 Corvette 200,255 HP 4 bolt main 3970014 350 69-77 Pass,Chevelle,Camaro, Nova,MonteCarlo 2 or 4 bolt main 3970014 350 69-79 Truck 2 or 4 bolt main 3970014 350 72 Corvette late &undefined;72,200 HP,255HP 4 bolt main 3970020 307 68-73 Pass,Chevelle,Camro, Nova 3970020 307 69-73 Truck 3970024 307 69-73 Pass,Chevelle,Camro, Nova,Truck 3992386 327 68-69 Pass,Chevelle,Camro, Nova,Truck Large Jounal
Oct 13, 2014 | Cars & Trucks
I cannot find the right way to hook my TS-W304C Subwolfers up to a mono channel amp.
what amp? the speaker wiring depends on the ohmage rating of the amp. if the amp is 2 ohm stable, then you can hook 2 TS-W304C's up to it, both positive leads from the speakers attached to the amp positive, and both negative speaker leads connected to amp negative. this is called parallel wiring, and it reduces the ohmage (resistance) down to 2 ohms. your speakers are 4 ohms, and 2x4 ohm speakers in parallel makes it equal 2 ohms. if your amp is only 4 ohm stable, then you will only be able to hook up one of your speakers to it.
Mar 13, 2011 | Pioneer TS-W304C Car Subwoofer
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
How do i make my pioneer super tuner 3d 2 unmute? if i try 2 turn the volume up it just keeps sayin mute and i havent been able 2 find a mute button on it any where?
My Pioneer Super Tuner 3 D was working just fine. The face plate was removed by accident while it was operating. Once it was reinstalled the displays all still work but there is no audio any longer.
Sep 25, 2009 | Pioneer Car Audio & Video
Car amplifier has been removed, it was obviously in the trunk hooked up to nine speakers, etc. I just bought the car and there is a pioneer cd player and a seperate cd/dvd player under the passenger side...
I will assume that none of those wires are marked, thus leaving you with the cumbersome task of tracing each wire to its place of origin and properly marking them.
I will also assume that you have a standard hardware configuration whereas the in-dash head unit serves as an input selector and pre-amp for your aux.CD/DVD unit.
A possible shortcut would be to first identify the two power leads( one is a constant 12+ volts & one is a switched 12+ volts that is a remote power lead from the head unit) and the ground that was ran to the missing amp, mark and separate those from the group. Then with a test speaker trial and error those remaining signal (speaker) wires with the in-dash CD player on and loaded so as to find that units signal outputs (there may be more then one pair) You will need to identify left and right output signal pairs by adjusting the head units L & R control and marking those wires accordingly. Next with a pair of signal leads with output, temporarily connect them to all of the other unidentified signal pairs as to determine its speaker and marking them accordingly. At this point you should be able to make your left and right speaker connections.
Note: it will be wise to have a DC voltage tester to check for the missing amp power leads and signal polarity especially if you plan to install a new amp.
I hope this sheds a little light on your problem.
Good luck
Aduz
Mar 14, 2009 | Pioneer DEH-2900MPB, MOSFET 4x50W Max WMA,...
Removing dash board from 1969 chevelle
you will find bolts in the defrost air vents and under any speaker covers. also in the glove box. make things easy and remove the windshield first. can be done with the windshield in place but much harder.
Dec 04, 2008 | Chevrolet Chevy Cars & Trucks
Pioneer car stereo instalation
if they are all positive speaker wires then each speaker will get a positive and the other speaker wire goes to the ground of the ground wire
Oct 12, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Wiring color codes for pioneer deh-425
Yellow: battery power Red: switched power Black: ground White: left front speaker Gray: right front speaker Green: left rear speaker Violet: right rear speaker Wires with stripes are the negative speaker leads.
Jan 21, 2007 | Pioneer DEH-425 CD Changer
Car Audio & Video Logo
138 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
