Question about Dell Computers & Internet
What is most common prob. with Dell U5427 PWR Supplies for GX280 Small Form Factor comp.?
  • 1 more comment
  • cici71 Jul 30, 2009
    I switched pwr supplies with a good running computer and that is how I know the one
    in question is defective. The supply has another number: HP-L161NF3P. I am looking
    for a specific part number for a spcific problem, such as that which is provided to electronic
    repair depots using a manual known as "Sam's Photofacts." Hope this helps. Jim Cole
    Saiki006: That Link you provided proved that I had the wrong pwr supply number.
    I opened up the defective supply and I will send it to Davey Jones's Locker at the
    bottom of the Pacific Ocean!! I will no longer waste any more of your time. Thanks
    for your splendid effort. Take care, Jim Cole
    Saiki006
    Ok, Thanks. I'm sure the very moment this thing lands on the
    ocean bottom my luck will turn Reaaaal Gooood. ha ha Jim Cole
  • 453 Answers
There must be no problems with the above mentioned power supplies as it is the recommended for the Dell Optiplex GX280.
Are you facing any problems with it? If so, kindly let me so that we can troubleshoot further.
Posted on Jul 30, 2009
  • 2 more comments
  • Sai Kiran Camsarapalli Jul 30, 2009
    If there is any problem in general then it could be with the Main board but may not with the power supply.
    Any defect with the power supply can be evident by a burning smell or a shorted circuit.
    May be over voltage could be an issue causing the fuse in the power supply to fail.
    In any case it is always recommended to replace the entire supply rather than repairing the same.
    So from the above post I can see that you are looking for the part number of the Dell Optiplex system in which the power supply has gone bad. Is that right?
    If that is what you are looking for then here it is
    Dell Part Number : P5795
    http://accessories.us.dell.com/sna/produ...
    Look for further information about the Power supply in the link above.
    Hope this helps/
    That's great !
    You can always connect back to this thread if you have any issues.
    Good luck !
Optiplex replace power supply
Hello Jacey,
Below are the system specs for the power supplies that are installed in each chassis of the GX280 system. You can call the Dell Spare Parts
Department at 1-877-717-3355 or click the link below.
Spare Parts Department
Wattage small form-factor computer: 160 W
small desktop computer: 210 W
small mini-tower computer with processor speeds of 3.2 GHz or lower: 250 W
small mini-tower computer with processor speeds of 3.4 GHz or higher: 305 W Heat dissipation small form-factor computer: 546 BTU/hr
small desktop computer: 717 BTU/hr
small mini-tower computer with processor speeds of 3.2 GHz or lower: 853 BTU/hr
small mini-tower computer with processor speeds of 3.4 GHz or higher: 1041 BTU/hr Voltage fixed-voltage power supply-110 V at 50/60 Hz manual selection and auto-sensing power supplies-90 to 135 V at 50/60 Hz; 180 to 265 V at 50/60 Hz; 100 V at 50/60 Hz for Japanese computers
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 23, 2013 | Dell OptiPlex GX280 PC Desktop
Dell GX280 orange light on MOBO
Dell Support > Optiplex GX280 Desktop PC > User Manual,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tindex.htm
I chose the Mini-Tower model because the following information applies to all models;
Small Form Factor (SFF)
Small Desktop
Desktop
Small Mini-Tower
Mini-Tower
Computer and Software Problems > Troubleshooting Tools and Utilities > System Lights,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tools02.htm#wp1114432
Now scroll down. What do the Diagnostic Lights indicate?
Post back in a Comment.
Regards,
joecoolvette
Oct 09, 2012 | Dell OptiPlex GX280 PC Desktop
Issues with 2gb 32ddr dell memory compatible in dell gx280
Unfortunately, the CPU on these computers may be capable of handling the 2GB memory, the motherboard isn't on either system.
The specs for the Dell GX280 are available here: http://support.dell.com/support/edocs/systems/opgx280/en/ug/specs02.htm . This system takes 400 or 533 MHz DDR2 non-ECC memory and the form-factor determines the maximum memory. In the mini-tower format, you have 4 DIMM slots and can have 4 GB of memory. In the small form factor, it takes 2 GB max.
The Dell E310 specs are available here: http://support.dell.com/support/edocs/systems/dim3100/en/sm/specs0.htm . This system can only support 2 GB (2 x 1 GB) memory.
I wish that I had better news for you.
(who had a similar Pentium 4 computer with the 1 GB limit. Since that system was running a 32-bit system and only actively addressed 3 GB, I didn't try to put 2 GB sticks in any of the 4 memory slots.)
Aug 30, 2012 | Dell Computers & Internet
Optiplex gx820 can i connect 300 watt power supply
You listed GX820 and GX260.
I am assuming you meant the GX260.
There are three varieties of the Gx260.
1) The SFF (Small Form Factor) power supplies can be replaced, but I know of no upgrades for these.
2) For the SDT (Small Desk Top), you can get up to a 270 (best I have seen).
Example of where to get one.
http://www.atxpowersupplies.com/180-watt-dell-power-supply-1n405.php?psu=1N405-GX260SmallDesktop
For the Mini Tower, here is an example of a 400W replacement. There may be others for this model.
http://www.cputopia.com/dell-400w-dell-optiplex-gx260.html
I have a GX280 Mini Tower and recently upgraded my PSU to one very similar to the one above.
Feb 21, 2011 | Dell OptiPlex GX260 PC Desktop
What is the most memory l can put in my dell optiplex gx 280 desktop ,l have 512 in it now
For mini-tower and Desktop
You should have 4 slots.
4GB is the max if you replace all the sticks.
For gx280 SFF (Small Form Factor)
You should have 2 slots.
2GB is the max if you replace all the sticks.
Nov 17, 2010 | Famous Brand Dell Optiplex GX280 Intel...
Increase the amount of shared video dell gx280
Hello!
Don´t lose time for that, I think that you have integrated grafik in own chip, and they have same options with 1 or 64 MB, option in bios, that isn´t a standard shared grafik. Try AGP card if you have a socet for that.
Oct 30, 2009 | Dell OptiPlex GX280 PC Desktop
Hi.Same problem.GX280small form factor.Power on
check your power supply, if it is powerfull enough to feed your card.
Oct 18, 2009 | Dell Optiplex GX280 (99301) Motherboard
I have Dell GX280 system. My Fan produces more sounds and runs fast. System Hangs while processing and performs slow, causes processor nore hot. I pasted the Heat Sink Paste on processor that resuls in low...
More than likely your fan needs to be replaced. These small form factor Dells are know for problems like this. Warning! Do NOT attempt to blow out the CPU fan with canned air, as this will likely lodge dust particles in the axis of the fan causing it to drag and become louder!
Sep 09, 2009 | Dell OptiPlex GX280 PC Desktop
Can i put Radeon HD 3450 graphics card in my DELL optiplex gx280 (small form factor)?
Yes as it has a pci express slot ,go ahead ..just uninstall the old graphics drivers in add remove programs.Switch off install card restart install driver.You may have to change resolution in display properties after it's installed.
Aug 04, 2009 | Dell 1505FP 15" LCD Monitor
Power supply
What you need to be concerned about with Power Supplies is the Wattage (The higher the better) and its "Form-Factor." A Form Factor is the general size and shape of the motherboard. The most commonly used Form Factor is ATX or Mini-ATX. I would reccomend figuring out what size your case is either ATX or Mini-ATX (Baby-ATX sometimes) and you should be able to decided whether the PS is too big. Too small isn't a problem as long as you can screw the unit in tight.
Jan 20, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
85 people viewed this question
Alun Cox
