Dell Studio 1537 Laptop Logo
Anonymous Posted on Jul 30, 2009
Backlight malfunction I have a Dell Studio 1537 and sometimes the backlight on my computer goes off when I am typing. Occasionally, it flickers on and off and it does not seem to be working properly. If I am typing in the dark I can't really see the letters. What can I do to make sure that the light stays on all the time when I am typing?
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jul 31, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
829
Points
10
The best way to check the ribbon's for your keyboard is by following these instructions directly from DELL:
http://support.dell.com/support/edocs/systems/studio1537/en/sm/keyboard.htm#wp1180346
This is a very simple process, but be sure to read through the entire process prior to starting.
Anonymous
Level 3:
  • Master 555 Answers
  • Posted on Jul 30, 2009
Anonymous
Master
Level 3:
Answers
555
Questions
0
Helped
226793
Points
1636
Kindly check if the back light you have is still functioning properly such as the buld is functioning, the connection of your back light is properly connect or have enough power to supply the need of the back light.
Thank you
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 283 Answers
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
283
Questions
0
Helped
67669
Points
768
The ribbon wire of the keyboard is lose contact. If you can do it by yourself, just remove the terminal then attached it again. But if you cant, then go to service center. tanx.
Vizio E480i-b2 LED TV loosing picture and sometimes shutting off
I don't think you had backlight issues like you thought you did as the set should have shut down the backlights totally as soon as it sensed over voltage or over current, I'd try a new main board and see if that fixes things up for you
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
CCFL backlight flickering or going out when adjusting screen
Yes you can replace the CCFL lamp.
To replace the CCFL lamp requires removing the front screen bezel, removing the LCD screen from the frame and the reflector which is located on the bottom edge of the LCD screen. The CCFL lamp is located inside the reflector and the electrical wires on the ends of the CCFL lamp are connected to the inverter board.
Replacement parts are available from these WEB sites. www.lcdparts.net http://www.lcdparts.net/adword/ledkit.aspx?gclid=COzzndCVvbYCFQFipQodrH0AJw http://www.yallstore.com
My dell Studio laptop takes too long to wake from sleep mode and the monitor just flickers when i try to switch on
If you use Windows 7, u might have hybrid sleep activated. This is similar to hibernate. When u choose SLEEP, your computer goes to hibernate. Sometimes this hibernate just hangs. You have to reboot computer.
Try pressing the power button for several seconds (10-15). It should power off the laptop.
If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
The backlight won't turn on but occasionally will flicker.
Suggest you replace the Inverter. A Backlight goes out all at once.
90% of the time the Inverter is the hardware part at fault.
[ An LCD screen cannot produce enough light by itself.
A Backlight is used to supply the needed extra lighting.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a much smaller scale
An Inverter is used to required power for the LCD screen, and the Backlight.
Boosts power up for the LCD screen, brings it down for the Backlight.
Dell Support > Latitude D600 Notebook PC > Service Manual
http://support.dell.com/support/edocs/systems/latd600/en/sm/index.htm
Replacing an Inverter is a simple job. Replacing a Backlight is not.
The Backlight is located within the LCD screen assembly.
The metal frame of the LCD screen assembly is removed along the edge where the Backlight is located, to access replacing the Backlight.
In the above list for Service Manual, click on > Display Assembly and Display Latch.
This information shows you where the Inverter is located on a Dell Latitude D620 Notebook PC.
The Latitude D620 is part of the Latitude D600 series of Notebook PC's.
http://www.insidemylaptop.com/remove-replace-lcd-screen-dell-latitude-d620-laptop/
Just one place from a quick search, that sells Inverters for a Latitude D600 series Notebook PC,
http://www.parts-people.com/index.php?action=item&id=2895
MATCH the part number listed that they have, to the part number on your Inverter.
You have to have THE correct Inverter.
Regards,
joecoolvette
2answers
I have a dell studio 1537 volume indicator stays on screen
Try system restoring it by going to the date that it worked. Just type it in the search box on your start menu and go to it and follow directions.
2helpful
I have a Dell Studio 1537 with Windows Vista I
try this first. download the latest webcam driver from the support site. uninstall the old driver then install the latest one. if fails, then download the system bios then install the latest bios to your laptop.
1helpful
Dell Studio 1537 DVD not working
1. clean your cd, then put
2. clean your cd/dvd head
3. scratch cd/dvd shows this type of message
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
