My ac fan is spinning counterclockwise resulting in overheating
I replaced my ac fan motor, I did the connection using the material that comes with the motor, including the capacitor. when the fan is on, it get very loud, and within a short time it shut itself up. What do I need to do to get the motor spin clockwise? I would really appreciate some help
smartou
  • smartou Jul 31, 2009
    My new motor comes with a capacitor, which I connect to the brown and brown/white from the motor. I connect the black and yellow from the motor to the black and white from the unit. Although I follow the diagram suggested, the fan continue to spin counterclockwise. I am about to return the motor to the shop; Is there anythings else to do to get it to spin clockwise?
    I would appreciate a some suggestions
    smartou
  • 867 Answers
You need to switch the two wires around for it to spin the other way
Posted on Jul 30, 2009
My 1994 grand am electric fan will not come on. Why?
Is the engine overheating? The fan is computer controlled and only comes on at about 210-220F
Apr 06, 2016 | Cars & Trucks
2008 pt cruiser overheating.
Probably not . check the fan fuse and coolant sensor first. check the fan spins freely(spin with finger)
Jan 12, 2014 | 2008 Chrysler Pt Cruiser
My Carrier rooftop ac blower motor quits blowing. It'll run fine for a while, maybe up to 8 hours or so and then just quit. If I go up to the roof and spin the fan motor and then come back down an
There is probably only 1 wire leading to the F or FAN terminal on the capacitor. You remove the 1 wire to the fan side of the capacitor and connect it to the new fan capacitor. Then you take an extra wire that you will need to make, buy, or find, and connect it from the opposite terminal on your new capacitor. Meaning the other side that of the capacitor. Then connect that new wire from the new capacitor back to the old capacitors C or COM terminal. Clear as mud I know, but basically you run your fan capacitor wire to the new capacitor, then the other side of the capacitor runs back to common on the old capacitor. And beware! Those things can hold a charge!!! Disconnect all power & discharge the capacitor! Hope this helps
Mar 02, 2017 | Heating & Cooling
My True TD 50 18 beer cooler does not cool beers
If you hear a clicking noise coming from the compressor there is about a 80% chance that the compressor is dead. But you'll have to call someone out to be sure.
If the fan motor behind the grill is running (condenser fan) then the compressor should be running and vice versa. If the compressor is hot as a pistol and clicking and the fan motor is not working then it may cool down if you shut it off and you might just have a bad fan motor. With power turned off the condenser fan motor should freely spin. Compressor have a 5 year warranty from the manufacture not including labor and additional materials. Hope this helps.
Jan 14, 2012 | True Refrigerators
I have a lennox ac unit model M/n hs 29-029-2p S/n 5802g 11144 the fan just stop working and the motor was making a noise like it was humming plus no cold air was coming through our house we purchased it...
The fan stopped working and the compressor overheated due to this. Turn the disconnect (switch by outside unit off) and let cool.
Try spinning the fan by hand. If it moves freely replace the capacitor, if not replace the motor.
Aug 21, 2011 | Heating & Cooling
Hi I have a Brivis buffalo 80 heater,16 years old normally goes well. Piolet light lights and stay alight. Main burner starts up but when fan should come on all I get is a loud ac hum at the unit.The fan...
There is. Unfortunately it is on the main circuit board. To check pull the circuit board out and examine the bottom in search of a scorch mark where the circuit has overheated and burst. If so, replace the board.
Usually if I hear that hum it means the motor itself has burned out and needs to be replaced. since the squirrel cage spins free, it's possible that the motors capacitor isn't right, which caused the eventual burnout. be sure to check that if you replace the motor, just read the motor for the number and use a multimeter to check the capacitor. best of luck to you.
May 07, 2011 | Heating & Cooling
Car turns on ok gets overheated quickly only the motor fans spins the ac fan does not the water pump looks to be working fine theres coolant in lines and they not collapsed i replaced relays and thermostat...
you know the water pump for that particular car is on the other side? is driven by the cam... either your water pump is not working,(to remove water pump you need special tool) did you change the termostat? temp. sensor?
Mar 28, 2011 | 1998 Cadillac DeVille
The fans do not work and the vehicle starts to over heat
With mechanical fans, most overheating problems are caused by a faulty fan clutch - though a missing fan shroud can reduce the fan’s cooling effectiveness by as much as 50 percent (depending on the fan’s distance from the radiator), which may be enough to cause the engine to overheat in hot weather or when working hard.
Defective fan clutches are a common and often overlooked cause of overheating. The shear characteristics of the clutch fluid gradually deteriorates over time, with an average loss in drive efficiency of about 200 rpm per year. Eventually slippage reaches the point where effective cooling is no longer possible and overheating results. (On average, the life of a fan clutch is about the same as a water pump. If one needs to be replaced, the other usually does too.)
If the fan clutch shows signs of fluid leakage (oily streaks radiating outward from the hub of the clutch), spins freely with little or no resistance when the engine is off or wobbles when the fan is pushed in or out, it needs to be replaced.
With an electric cooling fan, check to see that the fan cycles on when the engine gets hot and when the air conditioner is on. If the fan fails to come on, check the fan motor wiring connections, relay and temperature sensor. Try jumping the fan directly to the battery. If it runs, the problem is in the wiring, relay or sensor. If it fails to run, the fan motor is bad and needs replaced.
Hope help with this.
Mar 12, 2010 | 1999 Dodge Grand Caravan
Kenmore AC unit's fan won't blow at all
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Jul 30, 2009 | Heating & Cooling
Maytag window ac unit
Feel the motor and see if hes hot ...... spin the fan by hand and see if it spins freely  if not the bearings have seized up.   So either rebuild the fan motor simply by replacing the bearings and oiling them and that should fix your problem.    IF the fan spins freely   OHM out the fan  and make sure there is no shorts or openings in the fan.     if your fan motor checks out good both mechanically and electrically  then your next step is to check the capacitor and control board
Oct 07, 2007 | Maytag M6D24E7A Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
