Question about Maytag SkyBox MBV1976A Beverage Dispenser
Skybox What does it cost to replace the control board?
  • 298 Answers
Is this it
hope this helps you
Posted on Nov 24, 2007
My Matag Skybox compressor will not turn on. I can here it clicking and trying to come on.
HI. This is a strong indication of starter/overload relay failure. This clicking noise is coming directly fromm the relay device. it is damaged. this relay is the main starter of the compressor unit. It receives a signal from the main PCB. Once the power signal is received, the relay will regulate the starting, and stopping of the compressor, via control board and thermostat assembly. The failed relay will need to be replaced, asap. Once replaced, the unit will operate correctly. The relay is mounted on the side of the compressor. Once the bracket, and terminal wires are removed, you can gently pull it away form the compressor, to check the contacts and connections for corrosion. If any of the contacts or terminal connections are worn, replace them. Worn contacts, or corroded connections will not allow for proper current flow.
NOTE_ I would advise to locate the clicking. Make sure its coming form the compressor/relay location. There are some units of this nature out there that are fixed(compressor and relay intergraion). If this is the case, simply replace the entire compressor unit. If the clickiong is coming from the main control board(PCB), the PCB, will be the culprit.
Dec 01, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox stopped cooling Skybox stopped cooling. Sounds like the relay will kick on briefly and then click off. Everything else works. I took the back panel off and could hear the relay clicking on...
The relay on your box is damaged.. You have to get it replaced.. Not to be tried by a novice but if you have some experience in electronics it can be fixed by you. The relay costs around 75$. Good luck!
Mar 26, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Need a part dispensing moter shot
The motor was never offered as an individual replacement part. The entire dispenser assembly was the only way the motor was availabler. Marcone Appliance Parts (1-800-482-6022) shows a single dispenser (11001187) left in their national inventory in the Jacksonville, FL location.
Mar 15, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Removing compressor from skybox
Maytag never offered a replacement compressor for the SkyBox units. It was not a cost effective repar to make. If you are sure the thermostat is supplying 120VAC to the compressor, you can install a Supco URCO410 relay/capacitor/overload kit. This part should only be installed by a qualified service technician.
Feb 22, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Removing compressor from maytag skybox machine
Maytag never offered a compressor as a replacement part for the SkyBox. It simply was not cost effective. If you are sure the thermostat is supplying 120VAC to the compressor, then have a qualified service technician install a Supco URCO410 relay/capacitor/overload kit on the compressor. As with any sealed refrigeration system, the US Environmental Protection Agency requires that a certified refrigeration technician recover the refrigerant charge before accessing the sealed system.
I hope this helped.
Maytag skybox soda dispensor does not get cold
sounds like the comp relay is bad or the compressor itself is bad the relay is inexpensive and easy to replace. the compressor on the other hand is not available to be replaced for this unit as well as cost prohibitive.
Jan 22, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Hinges on door. has the item
look up that web site and put in the model number
look in the parts photo item list for part #20 -- it is the replacement hinge---costs about 10.00
Jan 08, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox
Looks like I found the answer to the problem of Skybox not dispensing. I replaced the sensor in the dispensing door and my Skybox now works great!
Part is available from just look up your Skybox model number, mine was Skybox model MBV1976AAB. The diagram on the website should show you the exploded view of the door section of your Skybox. You are looking for part number 901892 or on the exploded view it will be number 21. The Maytag part number is 11001182, board flipper sensor. My Skybox had been down for two years and now works again!
Mar 27, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
