IP address to connect HP2035N on the network
How do I assign an IP address to connect an HP 2035 N on the network?
    President:
  • 1,996 Answers
Here's a good tutorial that may help...
See this MS article, though you don't mention whether xp or vista....(see here for vista)
See here. and here for HP info.
For more info on TCP/IP see here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 30, 2009
Testimonial: "Many thanks for your help. You fixed my problem!"
HOW TO PUT MY IP.ADDRESS IN
Open the Start Menu, right-click on Network, and select Properties. The Network and Sharing Center opens...click on Manage network connections. Right-click on the network adapter you want to assign an IP address and click Properties. Highlight Internet Protocol Version 4 (TCP/IPv4) then click the Properties button.10 Nov 2013
How to Assign a Static IP Address in Windows 7, 8, 10, XP, or Vista
www.howtogeek.com/howto/.../how-to-assign-a-static-ip-address-in-xp-vista-or-window... HOW TO PUT MY IP ADDRESS IN Google Search
Dec 09, 2016 | Computers & Internet
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
I have hp printer 2035 when add to network not stop printing
If you have reused an IP address from an old or different printer then likely you have a stale print job that is spooling to the printer once you connect it and likely the driver is not compatible with the 2035. Try connecting the printer with a different address to see what happens.
May 12, 2016 | HP LaserJet Office Equipment & Supplies
Where is the IP address for Photoshop C3180
The HP Photosmart C3180 printer does not have wired or wireless network capability. It can only be installed via USB connection. There is no IP address that can be assigned as it is not a network printer.
Feb 07, 2016 | HP Office Equipment & Supplies
How to enter an IP address on a hp2035n
To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0
Jul 17, 2012 | HP P2035N LaserJet Monochrome Printer
Windows system error: "an IP address conflict wit...
This error indicates that you have two devices on your network that have the same ip address assigned to them.
If you have have ip addresses manually assigned to your network devices you can open a command prompt and enter IPCONFIG, this will tell you what the ip address is of the device that is giving you the error. This ip address is assigned to another device on your network.
You can either change the ip address of the device you are receiving the error from or find the device with the same ip address and change that one.
Alternatively, if you have a router that that has DHCP enabled you can change the properties on your network adapters to obtain the ip address automatically by going to Network Connections, right click on LAN connection and click properties.
May 21, 2010 | Computers & Internet
HP laserjet 2015dn IP address problem
please do not assign dynamic IP on the network printer. give a static IP on it base on your network config. and also, please do assign all you computers on the network with static IP's so that every time they boot there will be no IP conflict or problem on the network connection.
Mar 05, 2010 | HP LaserJet P2015dn Printer
No ip address
Network Card's driver is not installed. Check and install drivers from Device Manager Window.
IP Address can be assigned automatically(through APIPA/DHCP) or Manually.
Automatic:
There is no DHCP server, it takes the Automatic Private IP address(APIPA) or else get it from DHCP server by using "ipconfig" command
Steps: Start>accessories>command prompt>ipconfig /renew
Manually:
Right click on My Network Places> Properties>Right click on Local Area connection>Properties>General Tab>select Internet Protocol(TCP/IP)> Properties>General> select "Use the following IP address> assign IP, Subnet Mask, Gateway and DNS> Press OK Tab.
Dec 10, 2009 | Dell Dimension 3000 PC Desktop
How to assign IP address to HP procurve1800 switch?
The 1800 series do not have CLI so you should connect directly to any RJ-45 port.
I quote from the installation guide:
"In the factory default configuration, the default IP (Internet Protocol) address of the switch is 192.168.2.10 and the subnet mask is 255.255.255.0"
So set your PC IP address in the same subnet and access it through your web browser. If it has not the default configuration, interconnect the switch ports 1 and 2 and reboot it.
Hope this helps,
take care
AFO
Dec 31, 2008 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
4,064 people viewed this question
jasbo
jasbo
