Question about Protron PLTV-32 Television
Cannot get little box off
I have a picture on the full screen with a little box with another channel and i cannot get the little box off.
    Brigadier General:
  • 6,966 Answers
You need to switch your PIP (picture in picture) feature OFF. It's either one of your remote buttons or inside the menu/settings.
Good luck and kind regards.
Posted on Nov 24, 2007
  • Louie  Role
    Louie Role Dec 03, 2007
    Hi again,
    How's your concern? Was it resolved?
When I click to open Netflix from Roku, there is no title pictures showing in the little boxes. There are only little pictures of a TV. What happened
  1. Press the Home button to navigate to the Roku home screen.
  2. Select Settings.
  3. Select Netflix Settings.
  4. Select Deactivate this player from my Netflix account.
  5. Select Yes. The device is now deactivated.
  6. Select Netflix from the home screen and follow the prompts to reactivate the app.
  7. Sign in to your account and try Netflix again.
All other Roku models
  2. Highlight the Netflix app and press the star key on the remote.
  3. Select Remove channel.
  4. Select Remove channel again to confirm.
  5. From the home screen, select Streaming Channels.
  6. Select Movies & TV.
  7. Select Netflix.
  8. Select Add Channel.
  9. Select Go to channel.
  10. Sign in to your account and try Netflix again.
Sep 25, 2017 | Televison & Video
Cant get full screen picture on my Sky tv channel
The set or a box if used may be able to correct this--some programs are only in letterbox or 4x3 format.
Question: Does the set play a full screen version of a DVD?
Jun 07, 2012 | Televison & Video
Can't get full screen
I have a Vizio. If I use the HDMI input I can only get normal and zoom w/ picture buttom on the remote but get full picture on all cable supplied HD channels but not on none HD channels. However, if I switch cable input, I have the TV set up with both inputs from the converter box, I am able to have the options of normal,panoramic,wide and zoom on all non HD channels. I don;t like the black bars top and bottom of the HD channels with this imput mode so I switch back to HDMI. Maybe your TV is simmilar.
Jun 28, 2009 | RCA L32WD22 32 in. LCD HDTV
No full picture.
Are you on cable or converter box? this may be why if you are using converter box.readjust your zoom and see if this helps.
Apr 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The lower half of the screen is a black box on one channel
Check your closed-captioning settings. You probably have it set for "text". Make sure you turn captioning off and the problem should clear up.
Feb 12, 2009 | Recoton Advent Advent Q2035A 20" TV
Bad Picture
When you say messed up do you mean the convergence is out? please explain a little more detail as to what you are seeing. Also when its messed up if you press the menu button on the remote does the menu look good?
Sep 10, 2008 | Toshiba 50H81 50" Rear Projection...
Red Vertical Burn Line on LCD Screen
Try changing the picture setting on the television rather than from the picture box.
Sep 09, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
The black box is caused by the Closed Caption option of the tv. Go into the menu and turn it off.
Jul 18, 2008 | Insignia IS-LCDTV32 32 in. Television
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Full screen view
in order to get the full HD experience you should be using HDMI cables. if you're using the white/red/yellow cables then your HD channels will not broadcast in full HD and you'll be stuck with the annoying black things around your screen
May 21, 2008 | Vizio L32 32 in. LCD HDTV
Protron PLTV-32 Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
