Question about Pro-Fit Pro.Fit Fo 71 02 Ford Explorer/Mercury Mountaineer Sable
It will not start by key but you can start it at cilanoid if ignition is on. It is not battery or cilanoid or starter. What could it be?
    Sergeant:
  • 436 Answers
Must be either ignition switch or starter relay.
Posted on Jul 30, 2009
New battery new cilanoid won't turn over
brake safety, brake must be held. Or it just has a bad starter.
May 07, 2014 | ATVs
Will not start,OR CRANK, NO NOISE
Do warning lights and gauges come on, when key is turned to on?
If yes, check for power on the small wire at starter solenoid mounted on the starter with the key held in start. If power at the solenoid, take starter off and test for a bad starter or solenoid. If no power at solenoid when key held over to crank, work back to the switch in the start circuit-starter relay, clutch or neutral safety switch,-power from the start wire out of switch is not getting to the starter solenoid.
If no warning lights or gauges work with key in on position, power is either not getting to switch (bad maxi-fuse or fuse link, or bad battery connections-clean and tighten, recheck)-or the switch itself is not sending power out. Check if battery is charged up. Check all connections and grounds for loose, poor connections.
The start circuit starts at the battery, then to ignition switch, then out of ignition switch on the start wire to the clutch switch (or neutral/park on automatics), and on , ending at the starter solenoid on the starter. Somewhere in your starting circuit, power is lost. Start at the battery-check charge, check connections, check ignition switch.
Aug 25, 2013 | Cars & Trucks
I've changed the alternater,starter, voltages
Troubleshoot first and then change parts! What was the original problem? It just won't crank over? The alternator just charges the battery the voltage regulator keeps from putting too much of a charge into the battery. Was the battery going dead? Did the vehicle start when jumping it with jumper cables? Too many unanswered questions to offer help, sorry.
Feb 26, 2012 | 2007 Ford Van E-350
My '97 Geo Metro LSi will not start. When I turn the ignition key on the buzzer, idiot lights, lights, horn, etc., everything electrical will work. If I turn ignition key to start, there is absolutely no...
It could be the starter, test the small wire going to the starter, it should have power when turning the key to start/crank. If it does, and the starter will not crank the engine, whack it with a hammer, if it then starts, replace the starter. If there is no power to the starter, then it could be the ignition switch, or the neutral switch, or a fuse/link blown.
Sep 06, 2010 | 1997 Geo Metro
I have a 97 cavalier and we put a new starter on and it wont start it will start if u jump it from the cilanoid is it a bad weir or the swich ??
yes, wire or switch. Trace back from the solinoid until you get the 12 volts the solinoid should get with key in the "start" position.
Aug 29, 2010 | Chevrolet Cavalier Cars & Trucks
Cub cadet 2140 wont start or turn over
check the cilanoid or the stater , you may also have a lose conaction, try cross jumping the cilanoid
Aug 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Ford 302 want start with key
replace starter solenoid
Apr 12, 2009 | 1987 Ford F 150
Wont start
Try replacing the negative and positive battery cables. Sounds like that could be your problem.
Feb 12, 2009 | 2000 Chevrolet S-10
1987 Chevy S10 won't stay running
is the engine running at unusualy low RPMs. if so the engine could be going.
Jan 26, 2009 | 1987 Chevrolet S-10 Pickup
95 F150 wont crank
the starter should be replaced. The solenoid is kikcing the pinion out but there is no contact being made to turn the starter motor. I have the exact same truck and before i changed the starter used the old starter tap trick. Tap the starter casing with a hammer and it should start turning again. hope this was helpful for you. Good luck.
Sep 16, 2008 | 1995 Ford F150 Styleside Regular Cab
Pro-Fit Pro.Fit Fo 71 02 Ford Explorer/Mercury Mountaineer Sable Logo
108 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
Craig Butler
Craig Butler
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
