Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
One ice cube gets stuck when being ejected out of the mold
    Scholar:
  • 117 Answers
You should try adjusting the ice maker water duration setscrew on the front of the icemaker(under the cover)There should be a pos and neg setting. Just incrementally set to neg and see if the smaller ice cubes will solve the problem. Hope this helps
Posted on Jul 30, 2009
Ice maker not making ice
Check and see if a cubes or cubes are stuck in the ejection fingers. If the ice mold is full try cleaning the bottom coils. If the ice mold is empty check the water valve solenoid. Most times both the ice maker and water valve gets replaced at the same time. Nothing inside the ice box controls the ice maker. It does it all itself all it needs is for their to be 35f in the freezer or better.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 06, 2014 | Amana ARSE66MB Side by Side Refrigerator
Sub zero 650 slow ice maker
Hi Maureen,
Your sub-zero 650 should produce about 8 cubes every 2 hours. It sounds like the heater beneath the ice maker may be wearing out. Ice makers use a heating mechanism to warm the cubes in the mold and force them to easily eject. If the heater is failing in the back slot, it could cause the ice cube to get stuck. If this is the case, you usually need to replace the part or the entire ice maker.
It is also possible the mechanism isn't properly aligned. You could try adjusting it.
You can find two manual on FixYa here: http://www.fixya.com/support/p24667-sub_zero_650_o_bottom_freezer
Otherwise, I suggest contacting their customer service or a technician: http://www.subzero-wolf.com/contact-and-support/index.aspx
Best of Luck!
Dec 09, 2013 | Refrigerators
Ice maker won't make ice after changing water filter
Have you tried adding a bit of water to the ice mold? Is their an ice cube stuck in the ice mold? If you have an ice cube stuck in there just heat the im with a hair dryer till the cube clears and fingers go around. Listen to see if you hear water going into the mold.
Oct 08, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice wont eject from mold
lglasoe --
Owners Manual is available online at:
[http://www.managemylife.com/mmh/owner_manuals/search?query=Kenmore+655532]
If ice is getting stuck in the mold, it usually can be removed using a plastic (not metal) tool to eject it. Sometimes using a cooking spray like PAM (very lightly) on the ice mold can reduce the tendency for the cubes to stick. If you are still having a problem, write back. -- SWT
Aug 22, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
The ice maker is not able to eject the ice cubes. You can see them partially exposed but they will not move. The unit keeps making noise...I assume it is trying to eject the cubes. How do I resolve this...
the under side of ice maker should be very warm. this is the heater that warms the ice mold . if its not hot ( warm) the the ice harvest is slow or not at all . if heater is bad or mold ruff or warn out . the ice mker wil have to be replaced . you can clean tray and use a food grade silcone and it will help if heater is ok .. mm .ps some times the ice cubes are too small and get jambed in the slots . if so adjust the cube side ( more water adjustment . this will correct the problem mm ..
Aug 17, 2010 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Ice maker doesnt eject ice cubes until i physically help turn the the timer
Hello. Turn off the water to the ice maker. Remove the ice cubes, use a blow dryer to dry the mold and then spray the mold with PAM cooking spray. Let that dry and then turn the water to the ice maker back on. Joe
May 05, 2010 | U-Line Icemaker
GE side x side When ice maker switch is on, freezer warms up
It sounds like the ice maker is stuck in the harvest ( dump ) mode , in the area of mold heater activation . This area , heats up the ice mold to unfreeze the cubes , and keeps rotating to dump the cubes . This heater , gets hot enough to actually burn you if you touch the mold .
I would remove the 2 screws holding the ice maker , unplug from the ice maker receptical , and replace the ice maker .
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker cannot eject cubes. I took off the front cover and found several contact points for checking the motor, water valve, thermostat, mold heater. There is also a line voltage and neutral contact. Are...
I usually replace icemakers as a unit. It sounds like the mold heater is out. The system cycles like this: Fill, freeze, mold heat, eject, and start over. The mold heater not working will prevent ejection.
Sep 09, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Ice stuck in ice cube tray
get a hairdryer to melt the cubes unless hot water can get poured in to mold to do the same
Aug 22, 2009 | Whirlpool Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
245 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
