Question about Kodak EasyShare V1073 Digital Camera
My new digtal camera for some reason turns on and turna off right away.. was not dropped or anythimg used it 2 days ago. the battery is fully charges
    President:
  • 2,761 Answers
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
Battery
Might be the camera's battery terminals, not the battery itself. Take a qtip and some isopropyl aclohol and clean the terminals in the battery well of camera.
Jul 23, 2013 | Nikon D3000 Digital Camera
My nex tech binoculars will not turn turn on . Batteries are good
Was the camera dropped??
If it wasnt dropped try changing the batteries.
install a new or fully charged battery/batteries into the camera.
1. If the camera is on, turn it off.
2. If any accessories (memory card, lens, USB cable, camera or printer dock, etc.) are connected to the camera, remove/disconnect them.
3. Remove the battery/batteries from the camera.
4. Verify:
That you are using the correct battery/batteries for the camera
That the battery/batteries are correctly installed
That the battery/batteries are fresh or fully charged
Follow the battery installation and charging instructions in the camera User Guide
5. Turn on the camera.
Feb 08, 2011 | Cameras
How to solve the problam of lens obtructed?
If the camera was dropped this fix will not help you.Otherwise try changing the batteries
4. Verify:
Feb 08, 2011 | Kodak EASYSHARE M1063 Digital Camera
Can't charge the battery
I didn't have the time to find out what was the problem cause i needed the camera immediately so i bought a new battery and a new charger.Thanks for the help!!
Aug 07, 2009 | Olympus FE-220 Digital Camera
One day camera just stopped turning on.
Try the following:
1). Check batteries whether they are fully charged.
2). Check with Battery terminal are clean. You can clean them with a ear bud using some alcohol or spirit. Wipe the battery terminal with a clean dry cloth.
3). confirm that the memory car slot/battery cover is securly closed.
4). Reload the battery several times. This will also remove poor contact between camera and battery terminals.
5).Check battery are loaded in the correct direction.
If the probem persists, you might need to take it to the service center.
Mar 02, 2009 | Casio Exilim EXZ1050 Digital Camera
Help
Wow, this is trully amazing. I went to do a search on why my camera wouldnt turn on the past couple of days, even after i charged all THREE of my batteries and found similar complaints within the same time frame!! WOW. We need to get together and fight this, cause its suspect!!! I bought mine in Mass, anyone else?
Jun 30, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Wont turn on
Possible failed battery showing fully charged but actually not -or even charger.No reset] Disconnect from the wall socket- re connect and tell us if the battery is now charging. If show full- replace battery. Also tell Sony customer support
Jul 31, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Olympus FE-115 : wont turn on..turns iself off!!!
I had the same problem and i called up cutomer support on 1300 659 678 (Australia) and they said that the problem may lie in your batteries. It was advised that you use Lithium batteries, and to avoid use of Alkaline, since they dont have the required power to operate the camera which is why it turns off right away. As to what type of rechageable batterires to use i am not sure, i think it was Nickel-metal-hydride (NiMH) batteries. Hope this solves your problem.
Sep 10, 2006 | Olympus FE-115 Digital Camera
DSC-T7 Power Problems
The only and the only solution is to get the replacement as this seems to be a defect in the camera and you should get it change immediately.
Sep 12, 2005 | Sony DSC-T7 Digital Camera
Kodak EasyShare V1073 Digital Camera Logo
76 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
