Question about Apple iPod MA446LL/A MP3 Player
30 GB ipod video
Pins bent in bottom, cannot connect to usb
Re: 30 GB ipod video - Apple iPod MA446LL/A MP3 Player MP3 & Digital Media Players
To unlock code to the ipod
Posted on Jan 02, 2008
0 characters
3 Points
Ipod video pin connector bent
If it is the pins within the iPod that you are refering to, go to th following website for the replacement parts and free instructions on the process. If this is not the issue you are refering to, pease do let me know.
Feb 15, 2010 | Apple iPod MA446LL/A MP3 Player
The iPod USB Charger
<p>The USB cable that came with all iPod has two purposes: to your device to your computer so you can update and add music, and iPod to charge. All iPods have a lithium ion battery stops charging when the battery is full, the total life of your battery is not affected if you leave the iPod is connected to a power source. It usually takes four hours to recharge most iPods. <br /> <p><br /> <p>1. Connect the USB connector into an available high-power USB 2.0 port on your computer. Low-power USB ports, such as those in external keyboards and hubs do not work. <br /> <p><br /> <p>2. Connect the 30-pin connector at the other end of the USB cable 30-pin connector on your iPod. If you charge an iPod shuffle, there is no dock connector port. Instead, use the connector on the other end of USB cable that fits in the headset. Set the iPod down and let it recharge. <br /> <p><br /> <p>3. Unplug the USB cable when the iPod battery indicator is full. If you charge an iPod shuffle, the green light will appear. <br />
on Aug 09, 2011 | Apple iPod touch
New nano will not connect to or charge through usb on computer, will charge from charger? other older ipods work ok
check and see if theres anything blocking the port on the bottom of the ipod or if any pins in there look damaged or missing if there just bent you can try and bend them back into place if there missing then you might need to just replace the unit
Sep 24, 2009 | Apple iPod nano
My ipod video 30 GB is only playing sound out one ear.
one of the connections in your ipod is broken/bent. there is no good way to fix this youself. contact apple or go to your nearest apple store to have them fix it
Aug 06, 2009 | Apple iPod MA446LL/A MP3 Player
My Computer and iTunes does not recognize my iPod
Look into the bottom of the iPod where the USB connects. Make sure none of the pins are bent and that there is no corrosion visible. Also, are you using the same cable when you connect the different devices?
Jul 31, 2008 | Apple iPod nano
The bottom part of my ipod is bent
so basicly the bottom connector is broke. possibly the whole mainboard would need to be replaced or simply the connector replaced
Apple repairs
Some tech might replace the parts for 40-60usd. I cant say for sure since I dont know how bad it is.
Apr 27, 2008 | Apple iPod MA446LL/A MP3 Player
IPod Video 30 GB won't sync to itunes
  1. Okay you will have to Uninstall iTunes.
  2. Go to START CONTROL PANEL and ADD OR REMOVE PRGRAMS uninstal itunes.
  3. Go to
Nov 26, 2007 | Apple iPod MA446LL/A MP3 Player
İpod nano not seen at explorer and itunes
- check the cable - check the connections on the bottom of the ipod for bent pins, or dirt - make sure ipod battery is fully charged - if you have all your library backed up, reset ipod to factory. You will lost all settings etc. though. - check usb ports are working properly with no conflicts or driver issues (control panel\system\hardware\device manager) - uninstall usb ports on pc, let pc redetect them
Aug 25, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
60 people viewed this question
Top Apple MP3 & Digital Media Players Experts
 Mike M
Mike M
Ron Dufek
Ron Dufek
Raisin Brann
Level 1 Expert
Are you an Apple MP3 and Digital Media Player Expert? Answer questions, earn points and help others
