Question about GE DVLR223 Dryers
Dryer trips circuit breaker smell almost like something burning coming from dryer
  • GE Master
  • 1,151 Answers
In order to trip a circuit breaker, there is almost for sure, a dead short to ground. Takes quite a bit to trip a breaker. The smell is most likely something electrical burning. Stop resetting the breaker and have it checked out. Continous resetting and tripping can cause more damage. The breaker is doing it's job.
Posted on Jul 30, 2009
Smoke burning smell for transformer
YES! You must replace the breaker! Circuit breakers are made to prevent fires from over-current on the line that follows the breaker. If it was smoking, it means that too much current was flowing and it did not trip soon enough. Most breakers, whether they trip at 15 Amps or 150 Amps can handle a very quick pulse of up to 10,000 Amps, but that would not make them smoke: something went wrong. A circuit breaker is cheap. Your safety is not!
Feb 22, 2012 | Electrical Supplies
While drying clothes, the dryer suddenly quit. Smelled electrical burning (or over-heating) smell. Circuit breaker did not trip.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2011 | Dryers
We just started noticing that, when running the dryer, there's a smell coming from the breaker box. It smells like something electrical burning. The circuit breaker for the dryer was a little warm,...
A burning smell from an electrical panel is never a good sign. You did what a lot of people will do, and have the same results - the problem won't go away.
The circuit breaker relies on the mechanical squeeze pressure of its metal clips to maintain solid electrical contact with the panel's bus bars. The problem is likely due to a poor connection between the circuit breaker and the panel board bus bars. Over the years, the load presented by the dryer has heated those points, weakening the metal clips, changing the metal conductivity in some cases due to pitting and arcing. Changing the entire panel is probably not required - especially if there are other unused spaces for a circuit breaker to be installed.
If this is the case, I would remove the new QO230 circuit breaker and install it in a previously unused space in the panel, instead. The bus bar here should be undamaged (since it was never used before), as would be the new circuit breaker contact clips. The damage has been done to the bus bars at the original location, and that space should never be used again. The same holds true for the old QO230 circuit breaker. Install SQD blank plates in the panel cover to keep fingers from getting inside.
Next, a current reading should be taken with an ammeter or amprobe. A 30 amp breaker should have no more than 24 amps on each wire connected to it. If yours is more than that, something is wrong. If it is not more than 24 amps, measuring the voltage at the breaker and the dryer plug should be done as well. The voltage at the plug should not be more than about 3% lower at the plug.
If there is no more room in the panel, a secondary panel can be installed adjacent to and fed from the original panel, space permitting. Move the dryer circuit to the new panel and any two adjacent poles of circuits (for a 240 volt feed). The dryer circuit breaker space will be abandoned and the two additional poles will be fitted with a new QO circuit breaker to supply the new panel. Your electrician should do this work for you. This is "permit required" work and must be inspected for your safety.
I hope this helps and good luck. Please rate my reply. Thank you.
Jun 01, 2011 | Square D Qo 200 Amp 40 Circuit Indoor...
Had "burning" smell during dryer
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Feb 27, 2011 | GE Dryers
Dryer smells like something is burning and keeps tripping breaker
Make sure you have the plug wired correctly. Do not keep popping your breaker. I would advise calling an electrician.
Aug 18, 2010 | Dryers
Dryer won't heat up during dry cycle
Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Thank you
Jun 09, 2010 | GE DBSR453EBWW Electric Dryer
Comes on and kicks breaker smells like something is burning
if you smell burning then i would say the transformer is burning and if will trip breaker . some times the mag has failed causing over load to trans and both will have to be replaced. this is a big buck repair . you may want to replace ..
Jan 04, 2010 | Hotpoint RVM1435 Microwave Oven
Dryer keeps tripping breaker. slight burning
The heating element is shorted. This is an electric dryer, right? replace the heating element. Make damn sure it's un-plugged when you work on it!
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hoover HDC7FM condensor dryer starts then cuts out
Open the dryer door (right after the breaker trips) and check for a burned smell. If it smells in the dryer, you probably have a direct short in the dryer wiring. Check for a burn smell at the wall socket. There may be a short in the socket itself, but not likely unless a mouse is lying across the contacts in the wall.
If everything checks ok replace the circuit breaker if this is an older home. Circuit breakers weaken after years of use. A 30 amp circuit breaker will trip at a much lower amperage after a period of years especially if it has tripped often.
Mar 12, 2009 | Hoover HDC7FM Dryer
No heat coming from Dryer
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Heating element
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
Sep 01, 2008 | Kenmore 62882 Electric Dryer
GE DVLR223 Dryers Logo
327 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
