Question about RCA HD50LPW175 50" HDTV
I have a 50 inch RCA HDTV which has been working fine until the lamp blow and I changed it and the all of a sudden the picture and the color appears to be double then the color fades and it becomes more gray then it turns off and on. Any ideas on what caused this. Thanks
  • RCA Master
  • 5,807 Answers
there are many possibilities
a) turns on and off - might be on the power supply board
might be bulge or dried capacitors on the secondary side of the chopper transformer
b) color appears to be double -- convergence problems
might be open fusible fuse, or capacitor
c) more gray -- digital circuits
Initially can be check by a visual inspection of the boards, then the voltage checking on some points.
important is the B+ it determines the status of your TV, once it is noted some points can be isolated and checked.
include the make and model of your TV .
hope i have helped you, thanks for using Fixya!
Posted on Jul 30, 2009
Lost picture but sound is on
almost certain this is a lamp problem, bulbs blow up
if you remove the lamp you can see if the bulb is broken inside.
Jul 19, 2010 | RCA HD61LPW165 61" Projection HDTV
I have a 50 inch RCA Real Projection TV (DLP or HDTV). I just replaced the lamp and everything worked fine. One night it made a big sound and shut off. Now when you turn it on, nothing appears, a few...
you could have a color wheel problem or a power supply problem
one questions did you reinstal the door at the rear
you might want to remove the lamp module and try a reinstal and see if condition changes
as to costs if you can get the color wheel 150.00 or so
there ae several things that could cause this a dmd module a color wheel and power supply or digital board the lamp cover when installed it closes a saftey switch there thats why i ask if you has installed door
Oct 22, 2009 | RCA HD50LPW175 50" HDTV
How can i check my lamp ballast in a rca scenium 50w151 everyone tells me its my color wheel because i replaced my lamp and since then my tv wont even start up the light blinks then it stays on for a while...
are you sure when you replaced the lamp you seated it correctly, no really hapens all the time so dont feel bad. also another common error is the lanp door is not seated or closed and locked properly that is the most common problem that happens after a lamp is replaced, or the new lamp is bad never throw out your old one as somr dealers will give you what they call a core refund , they reuse the case around the old lamp. some can be worth as much as 50 to 60 bucks!!!
Larry Dillon
(AKA) (TECHMAN)
Sep 04, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
My picture is gone crazy
Call a good TV Tech and have him replace the color wheel assembly.
Jul 29, 2009 | RCA HD50LPW175 50" HDTV
The picture menu guide and color is distorted.
first thing you do is to check if cold solder in main board. it is in chroma ic. there are many causes of this trouble. it might be also the tuner.
Jun 15, 2009 | RCA HD50LPW175 50" HDTV
50Inch RCA dlp Scenium
Its the color wheel assy. Its changing speed due to worn bearings. You may also hear a hum coming from the rear of the TV. Seek an RCA authorized service center to resolve this.
michtech
Feb 12, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Color blinkig in and out.
It seems like the color wheel might start to fail.
Do you hear any abnormal sound(s) from the TV when ramdon color appears.
Would you be able to check and make sure all the fans are working properly?
Jul 13, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Dlp 50 inch
sounds like the DM3 isnt powering up the ballast to light the lamp or the ballast may be faulty. i would suggest trouble shooting the DM and ballast voltages.
May 28, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
RCA HD50LPW175 50" HDTV Logo
37 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
