Question about Samsung Televison & Video
TV has sound but the screen looks like it is going out has double, colors green, yellow, red. Went off by itself once. Wavy looking. Smelled burning in back, when it went off by itself.
  • 476 Answers
You're describing a power convergence amp problem, usually starts out at random color shdes or gohsts around the images more noticeable on scenes with letters or horizontal and vertical lines. the power amps overheat and sometimes will short out causing the fusible resistors to burn out. these amps are usually mounted on heavy metal dissipation units in one of the main boards.
Posted on Jul 30, 2009
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
My toshiba tv 50h81 has double letters red and yellow it fails the touch tone test every time
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV2_bing.gif may have one or more of the following symptoms....
Apr 08, 2010 | Toshiba 50H81 50" Rear Projection...
Objects are doubled and colors are distorted
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 11, 2010 | RCA R52WM24 52" HDTV Projection Television
Picture is wavy and double vision
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Jan 06, 2010 | Hitachi 46F500 46" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
I HAVE DOUBLE COLORS ON SCREEN THE RED AND THE BLEU AT ONCE ON AND I DON'T KNOW HOW TO ADJUST .
*Screen Looks 3-D
*Colors wont align
May 24, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Zenith R57W46 bottom bowing and color off and double lettering
*Screen Looks 3-D
*Colors wont align
Mar 28, 2009 | Zenith R57W46 57" Rear Projection...
Picture green and not clear, getting smaller, shutting itself off
*Screen Looks 3-D
*Colors wont align
Mar 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
Green and purple band of color
*Screen Looks 3-D
*Colors wont align
Jan 31, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Green Background with red wavy lines
*Screen Looks 3-D
*Colors wont align
Jan 11, 2009 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
44 people viewed this question
Jerry Greenberg
Jerry Greenberg
