Question about Brother MFC-5840CN All-In-One InkJet Printer
Brother MFC-5440CN printing business cards
Actually, I have TWO problems! I keep getting a message on the little screen "near empty yellow". There was still about 1/3 of the cartridge left. So, OK, I gave it the benefit of the doubt, I replaced the yellow cartridge and lo and behold I got a message on the little screen "near empty yellow"!!! Why? The next BIG problem. I do business cards for my son's business. I am trying to use the AVERY 8371 card stock, which is an ivory color which is what he wants. I might get one out of 4 pages printed, feeding them one at a time. Sometimes they won't feed and I get a message that I have a paper jam - sometimes the two top cards will just "break" off and it just keeps printing over and over and over on the same two cards. I have wasted more cards doing this - and they are not cheap! I was able to print 600 cards for him a while back - now it won't print properly at all and I am about ready to drop this thing out of a second story window and go buy an HP. My son needs cards, I can't print them, and it is EXTREMELY frustrating! Is there a solution short of getting rid of it? Thank you for any help you can offer and for your time. Waiting anxiously to hear from someone.
    Problem Solver:
  • 6 Answers
I think this is an driver issue. Try updating your driver and see if it works
Posted on Nov 24, 2007
Brother MFC-5440CN wont feed 2 colors of ink, Yellow and Magenta and also says
This may be due to the fact that you have not removed correctly the small label that seals the air input to the cartridge. Normally on brother cartridges it's on the back or on the top of the colored label. Please check that. If no air is allowed in then your ink will not be provided thus generating your problem.
Oct 27, 2011 | Brother MultiFunction Center MFC-440CN...
Brother MF 5440CN USB Printer won't print. Says "Ink Empty Cyn" and then "Ink Empty Yellow" Replace Ink There is ink in the cartridges.
While there may be ink in the cartidges, your printer is getting a signal from the cartidge that it's near empty. There is no real workaround for this; you just have to replace the cartridge(s). If you use a LOT of ink, you might consider installing a CIS (continuous ink system) now made for most printers. You will save a lot of money over time.
What you describe is typical.
Dec 06, 2010 | Brother MFC-5440 Printer
Printer keeps telling me that the yellow cart is empty and I have put a new one in
Are you positive it says the yellow cart is empty? Because that brother printer is designed to say that a cartridge is empty whenever ANY of the color cartridges are empty. Usually it doesn't tell you which one is really empty either. So even if you replaced the yellow cartridge and say, the black cartridge is empty, it still won't let you print until you replace that empty black cartridge, nor will you know which of the cartridges is empty unless you pull them out of the printer and manually check the ink levels.
Its pretty much a guessing game with those old brother ink printers.
Hope this helps :)
May 03, 2010 | Brother MFC-5440CN All-In-One InkJet...
I am getting the unable to print Error 4F message on my Brother MFC 5440cn printer
Error 4F:
The head drive voltage has
dropped from the high to
low level in an abnormally
short period.
Piezoelectric (PZT)
ceramic actuator
defective
You need to replace the print head.
Oct 06, 2009 | Brother MFC-5440CN All-In-One InkJet...
OCR with Brother MFC 5440CN
Abbyy finereader 6 works well with the 5440cn. The latest version is 9.
Apr 11, 2008 | Brother MFC-5440CN All-In-One InkJet...
Wont print
Check you documentation to see if there is a reset option. go to www.fixyourownprinter.com for further advice
Sep 10, 2007 | Brother MFC-5440CN All-In-One InkJet...
Near empty yellow
Do print until the message EMPTY (Printer stopps printing). DO NOT refill or change cart when message is shown: NEAR EMPTY! You fool the printers logic. Machine counts down the rest of the ink in the cart. When you refill at that moment the counter is disoriented! To clear the counter: Unplug powercord. Take carts out. Wait 3 min. Plug in power. Machine demands carts. Do use carts at full level (refill before you put them in). Works normal afterwards.
Sep 03, 2007 | Brother MFC 210C All-In-One InkJet Printer
Screen reads "Near empty Cyan" but I just replaced the Cyan ink cartridge, its full.
If the firmware update doesn't work, you can reset this error.
Unplug unit. Remove offending cartridge. Plug unit back in, wait until all startup noises have stopped. Open lid and reinstall cartridge. This will solve the fault as long as the sensor is working.
Also, please be aware, you should not have to change a cartridge if it says "Near Empty", only if it says "Ink Empty Magenta".
Also, please make sure none of your other cartridges are empty. I have seen this over and over. Two cartridges empty at the same time, and the person replaces one of them but thinks they actually replaced the other one.
Turn the power off and pull all the cartridges out. Look a the side of the cartridge, you should see a window with a little plastic tab sticking out. This tab should be blocked by a black float inside the cartridge. If you cannot see the float, and the tab is clear with no ink in it and no float tab blocking it, it means the cartridge is empty even if you still see some ink in the bottom.
To be sure plug the machine in without any cartridges. When all the noises have stopped, open the lid and install the cartridges. If you're still getting an error saying either a cartridge is not installed or is empty, then one of your cartridges is empty. Redo the previous paragraph.
Oct 05, 2006 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
385 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
