Question about GE Security Simon 3 Wireless Home Security System
Simon 3 - 6 beeps every 4 minutes or so
I recently purchased a house that has this unit installed and I unfortunately do not have a code to access the settings.
I can get the System Status messages which indicated that the door sensors needed batteries and have replaced them. However, it also indicates that the Date/Time has not been set and that the system battery is low. I can't set the date/time without the access and am not sure where the system battery is located.
Any suggestions?
Thanks, Scott
I had a problem just like your a few days ago. You see on the back of the alarm there is a red cable unplug it and unplug the power then open up the cover and press and hold at the same time the "cancel" "clock set" and "Minute Plus button" while plugging in the ac power. This will then set your password to either 1234,4321, or 6321 (Mine was 4321). That will allow you to enter the settings and disable the system beeps( Option 1). There you can also change the master code. The only drawback to my solution is that you will have to go around the house and press the button inside of them to reprogram the sensors. But if you wait about a week that battery like mine will probably recharge.
Posted on Aug 05, 2009
How do I reset GE Simon 3 Install Password to Default Password?
You need to reset the entire panel:
1. Open the panel cover
2. Uplug the transformer and disconnect the battery
3.Simultaneously press Cancel, Clock Set and Minutes buttons
4.reconnect transformer with button depressed.
5.Panel say"Hello System XX OK.
Panelis reset,installer code is 4321 master code is 1234
Jul 27, 2010 | GE Security Simon 3 Wireless Home Security...
Don't know access code. Bought used control panel
2. Unplug the transformer and disconnect the battery.
3. Simultaneously press and hold Cancel, Clock Set, and
Minutes +.
4. Restore power to the panel with either the battery or the
transformer while pressing these three buttons. The
panel announces “Hello. System XX OK.” Release the
buttons.
5. Connect the remaining power source to the panel.
- AlarmProfessor.net
Jul 16, 2010 | GE Security Simon 3 Wireless Home Security...
How do i program a keychain and the smoke dector
to program any new sensors first you must access the installer menu by opening the front cover and using the red buttons typing in the installers code,(4321) is the default code. once that is done press the add button, then the sensor/remote button, then trip sensor(keyfob by pressing both the lock and unlock buttons together until the system beeps) or (removing the smoke detector from the base until it beeps). Once the sensor has been learned it will say keychain remote, press the sensor/remote button repeatedly until it says the correct location, then press done. then enter group code 01 for the keyfob and 26 for the smoke detector. then done.
Sep 25, 2009 | GE Security Simon 3 Wireless Home Security...
Hello, I just purchased a GE SImon XT system with two motion detectors and a smoke/temperature increase detector. I live in a very small house and don't need more. Everything is hooked up and works...
Clarence,
If the problem is the Communication Failure, try to reprogram the Home Security System. The codes that you need are indicated in the user's manual. If reprogramming the Simon would not resolve the problem, try to get the master code from the manufacturer.
Reprogramming the device should resolves the issue.
Aug 25, 2009 | GE Security Simon 3 Wireless Home Security...
Need to change access code, but need ID. Is it on the main unit
Normally the default codes are either 4321,or 1234.
If those don't work you should try a reset by. first unplugging the red wire behind the system and unplugging the ac adapter. Then you press at the same time the "cancel button" "clock set button" and the "minute plus button" while plugging it in. After that the code should be either 4321, or 1234.
Jul 18, 2009 | GE Security Simon 3 Wireless Home Security...
New house, existing Simon3. How to access to add new sensors
Go to the GE Security website, register and download the installation manual. Heres the link:
https://portal.gesecurity.com/portal/login/login.jsp?TYPE=33554432&REALMOID=06-0008ce40-a18c-1536-85ea-8312f762000e&GUID=&SMAUTHREASON=0&METHOD=GET&SMAGENTNAME=$SM$wqmXYZlDF%2bp9wEfLtfJfgbvvO8xuG0aMyW%2fdUiDGhFTao1t%2b10TkWhV0hWcBh7VC&TARGET=$SM$https%3a%2f%2fportal.gesecurity.com%2fportal%2fmdme%2fDownload.jsp%3fID%3d320%26DID%3d320%26documenttype%3dInstallation$%20Instructions
The master codes are in the manual.
Or google "Simon 3 access code" or "Simon 3 ADT code" or such...
Jun 12, 2009 | GE Security Simon 3 Wireless Home Security...
GE simon 3 security system How to reset master code?
The default master access code is 1-2-3-4, try it to see if this works.
Apr 15, 2009 | GE Security Simon 3 Wireless Home Security...
It is possible to delete a lost 4 button remote key chain
Obtain the installation manual. You should be able to find this on Google. Search for Ge Simon 3 install manual. Follow te instructions for deleting sensors.
Jan 25, 2009 | GE Security Simon 3 Wireless Home Security...
Alarm on simon
Mike,
Unfortunately, without a code, there is not much you can do besides disconnecting the system. Do you own or rent? If you rent, call the landlord, he has to fix it immediately, as going off in the middle of the night and disturbing your rest is not acceptable. If you own it, find the main control box, which is most likely in a closet somewhere, and disconnect the 110AC and back-up battery. If you want the system to function, you will most likely need to call a local alarm company. Stay away from the large nationals, service tends to be poor. Find a local company, they depend on the individual customer to stay in business and you will get much better service.
Hope this helps.
Steve
Nov 14, 2008 | GE Security Simon 3 Wireless Home Security...
Beeps every 30 seconds
Remove the batteries or remove the power from it. (A plug-in transformer)
Oct 22, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
626 people viewed this question
Top GE Home Security Experts
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
