No boot when powered on it can not boot, not even the initial POST screen menu, also tried swapping ram and processor, help pls.
  • 596 Answers
Try pulling the CMOS battery out of its seat for about 5 min. Also, set the board jumpers pin to reset while the battery is out. Push the power on button, some model will power on into the BIOS setup. Here, set the system to default settings. Once done, power off the pc, reseat the battery and the jumper switch to normal. Power on your system.
Good Luck
C2Solutions
Posted on Jul 30, 2009
AT POST motherboard hang at INITIALIZING USB.....
Several things you can try:
  • Remove the CMOS battery leave for 10 minutes and re-insert and try to reboot
  • If this fails to solve the issue, check the BIOS (F2 on boot) and disable USB legacy support
  • Then if that fails, try swapping out the RAM modules until you manage to get a successful boot.
  • If you suceed in this, download memtest and check the integrity of the ram modules, it may be you have an intermittently faulty ram module.
  • If this fails, it is likely that the USB controllers on the motherboard are damaged
May 19, 2012 | ASUS P5GL-MX Motherboard
I have a Toshiba Tecra M2-S730 laptop that will not boot up. In fact, the laptop will not even enter the BIOS POST when power is applied. The CMOS battery (PN 710000033) is a 3.0v unit. I get a voltage...
is it come to welcome screen when power on? pls check the ram and clear cmos and try again. if not showing toshiba screen pls use usb post diagnostic card to identify the fault.
Apr 24, 2017 | Toshiba Tecra M2 Notebook
Hi i purchased an INTEL DG55 with core i3 processor and 4 GB RAM with 500 GB SATA hard drive , LG dvd writer. For some reason , after everything was assembled , Even when i load the windows cd , it...
If you have access to another computer you can make a bootable USB using the files from the CDs (assuming we are speaking of a bootable image file on the CDs).
If you have the Windows Backup that you created from the previous computer, that you will not be able to deploy on the new computer due to the changes in the hardware. This is most likely the reason that you get the BSOD.
Hope that helped.
Jul 03, 2017 | Computers & Internet
Wont boot
In that case, looks like you have a faulty motherboard (video chip) chip-set. Remove motherboard from the casing and apply thermal paste. Also clean-up the whole board. I hope this will help you.
machinetosh of (tipidpc.com) site
look for kuya boy laptop
Global PC Laptop Professional Services
09126888500
Apr 01, 2010 | Toshiba Satellite 1905-S303 Notebook
Acer aspire 5050 won't power up. have tried charger on different laptop and it works,
What you need to do is remove/replace "Bits" one at a time, ie: The hard drive, then the DVD, swap out the RAM... until it boots? or at least shows the initial screen. A laptop should display video with, just power adapter, RAM & NO Battery, HD, or DVD connected, although it obviously will not boot as such. If this still doesn't boot/show initial video after this you may find the Motherboard is faulty
Mar 08, 2010 | Acer Aspire 5050 Notebook
PC wont boot
The first thing to do would be to remove all non-essential hardware from the box, I mean everything. This will help isolate the problem.
Then remove all the RAM except the very basic amount. If it still doesn't work, swap out the installed RAM with the RAM you pulled possible and try it. This will isolate a RAM issue.
If that doesn't do it, you may also consider swapping out the video card. Before we go any further, try these things and report back.
Good Luck!
Jun 18, 2009 | ASUS P5AD2-E Premium Motherboard
Tecra M2 doesn't boot is it a processor problem?
given the symptoms, it points to motherboard.. if it was processor, video or ram. it wouldnt boot at all and you'd just get error beeps from your laptop. i'd first try resetting the bios, by removing the bios battery for 30 min, then putting it back in. if that doesnt work try changing it out, usually costs under 8 bucks. if that doesnt work then I would change out the motherboard, if its cost effective.
Mar 03, 2009 | Toshiba Tecra M2-S730 Notebook
WinXp wont boot after the initial installation
See if it will boot off the XP CD.If it does I would think you have a corrupt boot sector. Installing windows again should fix it if it is.
Dec 14, 2008 | ASUS P4SDX Motherboard
EPoX EP-9NPA7I displays 'F' and '5' post codes
I would start by clearing the CMOS with the reset jumper pin on your mainboard. Then remove all the PCI cards excluding the video card; disconnect the hard drive as well. Boot the computer without the RAM and see if you still get the "F post code." If not download a copy of Ubuntu Linux and burn it to a CD.
Ubuntu 8.10 Live CD
Reinstall the RAM modules and boot to Ubuntu from the CD and run "System Memory Scan" from the Ubuntu Boot Menu. I'm guessing your RAM over-heated and is permantly damaged.
Only the manufacturer knows what the error codes for your board represent; it'd email them from this support link...
EPoX Support Contact
Nov 27, 2008 | EPoX EP-9NPA7I (0819366003415) Motherboard
PC Won't Start After Initial Post
make sure the ram is the same name of kind. if you can get the old computer on, hit the esc key and go in the bois and hit save, and restart. this should bring the computer back up. check the piggs (jumpers) on the motherboard to see if all are the same, more them around and try each one, I hope this will help you.
Dec 16, 2007 | MSI K8N Neo2-F Motherboard
Computers & Internet Logo
David Payne
David Payne
