Question about Optoma MovieTime DV10 Multimedia Projector
Fan HiI think my fan has stopped working on one side of the unit. Air is coming out of the other side but is hot with a light burnt stinch. I've never payed any attention before.After about 3 minutes of playing a dvd on my Optoma Movietime projector, the unit will turn off (overheated I guess).How and where do I find a fan replacement? What type of repair shops should I look for.ThanksGeorge
  • George1052 Nov 24, 2007
    Hi
    Thanks but the manufacturer closed about 6 months after I purchased the projector.
    Problem Solver:
  • 6 Answers
To find for a fan replacement, it is always best to go back to the manufacturer of the projector
Posted on Nov 24, 2007
  • Chew Jek Hui Nov 24, 2007
    Maybe this website might help you
    http://www.bigscreenforums.com/forum_top...
I ve lot of problem when a stop in light o
Your fan on the engine is not coming on. It should have electric fans on the front that will cool the condenser. When you are moving the air traveling into the engine compartment is enough to cool the condenser. Mike. Rate 100% please.
Sep 18, 2009 | 2004 Chevrolet TrailBlazer
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Rick55 my outside unit goodman cjk484ab stopped working fan not turning motor very hot power went out for asecond then the unit stopped working i think the fan motor went out
check the capacitor if motor is real hot it might be burnt out winding can you get it to turn buy pushing the blades if so good chance it motor.
Jun 24, 2009 | Heating & Cooling
My air conditional unit outside ,fans turns on but the unit compressor wont turn on,just stopped working this morning.i turned the thermostat to 72 but only the fan on the outside unit comes on and it is...
Somethings aperson cant fix without a service tech. First it could be wire burnt of capacitor going to compressor. Second it could be bad capacitor. There is a dual capacitor on the ouside unit one side says herm that runs the compressor. Turn power off to check to see if wire is burnt of the herm terminal or the C ternminal. Wire burnt off compressor common terminal.. Could be locked up compressor. Unless you know how to troubleshoot unit. You may have to call service tech. Cost if bad cap. is about 100 to 150. But unit wont run without it. Rus
Jun 21, 2009 | Emerson Quiet Kool 12HT13 Air Conditioner
Lennox air unit not blowing cold air
your fan motor outside is going bad, have a service company change it out for you.
the motor stopped working and that overheated the compressor shutting it down on thermal cutout, and it will only come on once it cools down
Jun 16, 2009 | Heating & Cooling
Came home today and the AC will not come back on. The out side unit is working, but the blower inside will not come on. Also the light on the control board will not light up at all. Does anyone hav
turn off power to indoor unit feel the fan motor if hot and turns rough bad if hot and turns smoth then most likley capacitor if cold check 5 amp fuse on the board jump red stat wire to green if no fan relay bad if fan stat bad hope this helps
Jun 03, 2009 | Goodman CLJ30AR32 Air Conditioner
Exterior Fan not starting.
Its the problem with the fan. !1 or more coils have burnt out and if repaired will have to rewind the shorted coil/armature. Better to replace the fan. Also when getting it repaired ask them to check the thermostat too...............sodeep
May 16, 2009 | Heating & Cooling
Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Apr 22, 2009 | Kenmore Refrigerators
Not getting cool enough
this sounds like a compressor problem. if the outside coils are getting hot (and properly ventilated) but the inside of the unit is not getting cold then the heat is coming from the compressor.
Jun 28, 2008 | Dometic NDR 1292 Refrigerator
Optoma MovieTime DV10 Multimedia Projector Logo
268 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
