For Craftsman support (maybe they can get you a new key), go here:
https://www.craftsman.com/customer-care
For the manual, go here:
https://www.shopyourway.com/manuals/search?q=craftsman+247.887801
Good luck.
Hello, Walter -
You will find the link to the free download of the owner's manual here:
http://lawnandgarden.manualsonline.com/manuals/mfg/craftsman/247883550.html
Click on the Open as PDF link and save the manual to a file in your Documents folder. I suggest you print out the PDF document for easy referral.
The part number for the key is listed in the owner's manual, near the end. You will need that part number to order a replacement key through Sears PartsDirect:
https://www.searspartsdirect.com/partsdirect/brands/Craftsman-Parts
Best wishes.
SOURCE: i have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
SOURCE: I need a free manual for a Craftsman 15.5 CI,
Go to the sears web site, then go to parts section, then to owners manual section. Type in model and serial number. Then you can download the manual for free.
SOURCE: How to remove snow blower from Craftsman YS4500 garden tractor
Go to www.managemyhome.com to download the manual for free. Just type in the model # 944606950.
SOURCE: How to see if a used snow plow blade will fit my craftsman tractr
Underneath the hood of your tractor is a silver sticker with the sears item number for the correct snowblade. If its a craftsman snowblade it should have a meteal label on it with its model number the 5 numbers after the period need to be the same with what was under your hood to make it the correct blade
SOURCE: Craftsman manual for a 4 cycle lawn trimmer
I have a craftsman incredi-pull 4 cycle, I changed 4 cycle oil, too much smoke coming from the machine, what I can do?
