Question about HP (DM685A) Digital Pen
HOw do I attach the tether for my stylus for my HP tablet computer2710P. There is a string and a metal ring. It is not clear where the metal ring goes.
Ordered the PL800A (looks like it's identical to the UP-7116EA-81A-1) as I saw on a blog that it would work for all HP tablet PC's that have a digitizer. I have a HP Elitebook Revolve 810 G1 which HP says...
HP switch digitizers with the HP Revolve. Previous HP tc4xxx convertible tablets used a Wacom Digitizer, for the Revolve they are using a digitizer manufactured by Atmel. The change hasn't been well received as Atmel's performance has been horrible. If stylus performance is important to you, you would be better served with a different computer I'm sorry to say.
The only easily obtained stylus that is compatible with the Revolve is the HP Executive Pen but you have to be careful because the current HP Executive Pen featured on the HP website is for the G2 Revolve and it won't work with the G1.
The Part Number you need is H4E45AA I've included a link to CDW because their price was much lower than the price shown at Amazon
HP Executive Tablet Pen stylus H4E45AA Digitizer Accessories CDW com
Apr 07, 2014 | HP (PL800A) for tc4200
Tablet will not connect to wifi
When you tether with your Android-powered smartphone, you can connect to the Internet on your computer from any location covered by your cellphone service provider's network. Tethering allows your phone to act as a modem for the computer. Tethering applications such as Tether for Android allow you to set up tethering without the need to root your phone. Before tethering, check with your cellphone service provider to determine how much data you are allowed to use without incurring data charges. Excessive use of the Android phone as a modem can cause you to exceed your allotted data.
Search the Android Market on your phone for a tethering application. Applications such as EasyTether and PdaNet are available to download for free. Download the application from the Market. Installation begins immediately after the download. When installation finishes, an icon for the tethering app is placed on the Android's expanded home screen. Open a Web browser on the computer and access the site specified in the tethering application's description in the Market. Download and install the USB drivers needed to tether from the site. When installation is finished, an icon for the tethering application is placed on the computer's desktop. Tap "Settings" on your Android phone, then tap "Applications." Tap "Development" and enable "USB Debugging." When the field turns green, it is enabled. Connect the phone to the computer with its USB cable. Launch the tethering application on the phone. Launch the application on the computer. Click the option to connect to the Internet in the home screen. When the connection is established, confirmation is displayed in the status window.
Android 101: Tethering
http://www.androidcentral.com/android-internet-tether EasyTether shares your Android smartphone connection with your PC. http://www.mobile-stream.com/easytether/android.html
Apr 06, 2013 | Supersonic SC-75MID 7" Android Tablet
Free driver for pc tc4200 pen
The HP tc4200 uses a Wacom digitizer Given the age of the tablet you can get the Wacom driver from HP for Windows XP Tablet Edition
Drivers software
Feb 07, 2013 | HP Digital Eraser PEN with Tether for...
String broke on attached stylus
there should be screws holding it together, if not there will be a way to pry the casing apart, hope this helps you
Jul 01, 2009 | LeapFrog Leapster Electronic Book:...
HP TC1100
Try plugging in the tablet with the battery not installed. If there is no battery the tablet should turn on with just the AC adapter. If that works there might be a dead short in the battery and you would have to replace it
Jan 27, 2009 | HP DG937A - HP Tablet PC TC1100 Tethered...
Problems
The stylus pen works by pressure on the tip. Since the tc1100 uses an active digitizer, as soon as you come within range of the screen, the mouse should move (this is called pen-hover), however, if the tip is stuck upwards it will write or click instead just as if you were touching the screen.
Try carefully pulling out the tip using a needle nose pliers or your fingernails if they're strong, and then reinsert the tip gently. This should un-stick it. If this doesnt work, there may be an internal problem with the stylus.
Jul 26, 2008 | HP DG937A - HP Tablet PC TC1100 Tethered...
Sd card
have you try to insert it to another computer?
Feb 14, 2008 | HP DG937A - HP Tablet PC TC1100 Tethered...
HP (DM685A) Digital Pen Logo
347 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
