Question about Kenmore Washing Machines
Dose not do nothing
In have power to the countrole panle it shows a F on the panle
  • 15,935 Answers
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes:
* Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
* Check the MCU
* Check the Wire Harness
begin troubleshooting right at the motor. Why start there? Because the motor is one of the prime suspects and it's easy to check. Remove the back panel and unwind the belt from the drum pulley. Now turn the motor pulley (sans belt) by hand. If it doesn't turn smoothly and easily, you have a bad motor.
If the motor pulley turns smoothly and easily by hand, next step is to run the motor with the belt still removed from the motor pulley. If the motor seems to run fine that way, put the belt back on and run it again. If the motor won't run under load (with the belt on), then that's another sign that the motor is bad.
Suppose the motor turns easily and freely by hand but won't run either with or without the belt. This is a more subtle condition because we're probably dealing with a bad MCU or flakey wire harness somewhere between the motor and MCU, or between the MCU and the CCU.
One trick that often works at this point is to remove and reinsert all wire connections at the board and motor. This tends to clean the small amount of corrosion that will build up on the connections. After you do this put the machine into a service cycle (see the instructions in the tech sheet found inside the unit or you can ). Part of the service cycle is running the motor at certain set speeds which checks the tach.
If you've removed/reinserted the wire harnesses and still no joy, then usually the problem is the MCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
Wont power up, i replaced the power cable with a new one and still nothing, dose the transducer need to be connected for it to power on ?
The PWR button also adjust the backlight of unit. Press and quickly release to cycle through brightness settings. All else fails call Garmin www.garmin.com/support
Mar 25, 2016 | Garmin Echo 100 Fishfinder
Need key code to dell vostro3500 forgot password
hello i will show you your dell 3500 laptop problem just remove it ram panle box it show the cell remove it cell just power on laptop for 10 second and off it insert it cell sett the date and time your problem will
solve
Jan 15, 2014 | Dell Computers & Internet
My vizio 50 in tv powers on and green light comes on but it dose not display picture
This is a command fault. The Inverter is the most command reason.
flattvparts.co.uk
01329 825 403 - Monday to Friday 09:30 - 17:00
Dec 19, 2012 | Vizio P50HDTV20A 50 in. Plasma HDTV
Amana front loading washer won't run after power outage. Panle does light up.
Possible that the program controller unit has failed if there is no display or power in the indication. You will need to remove panel to check on the fuse and if the new fuse fails it is possible there are error or hardware failure within the board.
Please remove and check the power panel for shorted drive, rectifier or capacitor, if not the panel must be replaced.
Jul 04, 2012 | Amana Washing Machines
Air con blower dosnt work .
it could be as simple as a fuse mate have you tryed that?
Jun 06, 2012 | 1999 Mercedes-Benz C-Class
I need to take off the drivers inside door panle?
I think....
the crank handle is held in with a U shaped clip. Take a flat head screw driver and pry open the gap between the crank handle and the door panel. look in this gap and you will see the clip. Take another screw driver and from the end of the clip pop it off the crank handle. (you may have to rotate the crank handle to find the end of the clip). Another way is to put panty hose or a thin rang into the gap and rotate the crank handle, it will pick up the end of the clip and pop it off. (note: photo is from a different vehicle, but application is the same.) HTH
Jun 07, 2010 | 1999 Hyundai Accent
My wheelchair dose not move
The chair has two levers, one for each motor, that disengage it for freewheeling, or pushing the chair without power. These take it out of gear. Place the levers in the locked, gear-engaged position and it should go for you. Here's a link for the manual for your chair, and it will show you where the location is to place it in gear.http://www.invacare.com/doc_files/1125085J.pdf
Apr 16, 2009 | Invacare Pronto M51 Power Wheelchair
Lincoln impinger 2
this is caused probably by a faulty power board or a switch. In the front all three switches share a common power source. I would start there to see if voltage is present on all three switches. These are also tied into a 24 volt control transformer it would be the next thing I check I believe it is xfrmr 3 on the print.
Hope this helps Ya
please rate me
Feb 19, 2008 | Lincoln Conveyor Oven - 1133-000-A
Washing Machines Logo
27 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
