Question about Kitchen Ranges
Igniter has started sparking below the range top, not at the top of the electrode. I have a 5? year old Kenmore 75508. The one igniter has stopped working. It only sort-a worked for about a year, now its stopped. I still here it sparking, but nothing happens on the electrode end. I removed the white electrode from the range top and see that it is sparking, but below the surface. Around the bottom of the black insulation that I expect covers the connection wires. Can I just pull it apart and reconnect it someway? Should I get a replacement? Is there a manual someplace that can shed some light on fixing the problem? Thanks Jim
    President:
  • Kitchen Ranges Master
  • 1,922 Answers
Your insulation below the electrodes is breaking down and the hi voltage to make the spark at the electrode is grounding out...replace it...no fix
Posted on Aug 02, 2009
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Gas range won't ignite. We had PGE and come over
This sounds like a failed burner igniter, also called a spark module. These are pretty easy to replace since the module itself is located at the back of the stove under an access panel. The price is around 40 to 60 dollars. Lately it seems that these newer stoves have weaker spark modules. I see dead modules on models less than 2 years old, where it used to be more like 5 or more years on the older ones.
Mar 24, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Frgidaire Pro series gas range not lighting on one burner
there is probably some residue keeping it from sparking. look at 1 of the other burners and take mental note from where the spark is coming from. then spray just a little oven cleaner on and around the one not working. naturally take the metal grid off first.. let set for about 15 min. then wipe away the residue gently as not to damage the igniter electrode.. also there is a possibility the wire leading to the igniter fell off causing this problem.. do the explained first. good luck...
Nov 15, 2009 | Frigidaire PLGFZ397G Kitchen Range
Amana stove top burners click, and gas comes out, but won't ignite. It's a self cleaning ARG7200, about 11 or 12 years old. Oh, and can I lift this top? I'm used to doing that with old pilot-light...
A weak erratic spark from one or more electrode usually indicates a bad spark module. No spark from one of the electrodes while the others work properly usually indicates a bad electrode. Inspect the porcelain of the electrode for cracks, chips or burn marks. If there are any, the electrode should be replaced. If one of the burner knobs is turned to the light position and nothing happens, but all the others function correctly, the spark ignition switch for that one burner is likely bad. The switch can be taken out of the system and checked with an ohmmeter. It should close for continuity at the light position only.
Go here for:
Amana Range/Stove/Oven Parts
RepairClinic.com
appliance parts, help & more
Sep 21, 2009 | Amana Kitchen Ranges
Pilot on GE stove keeps popping non-stop
As far a "popping" do you mean the igniter on the cook top "clicking"? Did you clean the range and use too much water? If water gets into the igniter switches they will short out and constantly click. Also if the polarity at the electrical plug you can get what is called "ghost spark" so make sure that the polarity is correct at the electrical outlet. Each gas control valve has a switch that turns on the igniter when the knob is in a certain position and they are all wired in a sequence. One of those switches may be shorted out or have a loose wire(range dis-assembly required to inspect). Do you visually see a spark at the electrodes of the burners or do the burners ignite? If you cannot see the spark then there may be a grounding issue and possible loose wire.
Sep 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Range top caught fire
Hello vyoshikawa,
Welcome to fixya,
You said, the igniter had started by itself!
Please , do not play around with this issue!
You can try to pull the plug on this. And use service to diagnose this. We do not want you or your family to have a fire in the middle of the night.
If you need to use the range till they come and diagnose it, pull the plug when you are finished.
Pulling the plug for 5 minutes will perhaps reset the system, BUT this is no replacement for getting service in this case!
Let me know what happens.
Please remember to leave a rating!
Huuum,
Oct 02, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Igniter Problem on One Burner
Peace,
ngafm here at your service,
You may have some food that spilled into the burner and it could be causing the gas not to fully flow out of that one burner.
Or you just have a bead igniter.
If you have sealed burners and the cap and burner where the gas comes out, is removable by hand without tools!
You may want to check the gas holes in the removable burner is clear and or clean them out if they are clogged.
How old is the range?
I hope that these measures will help you remedy the problem simply and easily!
Bless you,
ngafm
Please give me a good rating in at this site before you sign off!
Thank You
Sep 04, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Igniter
check your polarity at your outlet polatiry very important to theese re-ignition spark module, next with an old nail file)emory cloth clean the tops of the electrodes, after a whitle of continous sparking they tend to build up w/ carbon making it unable to detect flame thus continous spark
Feb 04, 2008 | Amana ARGS7650SS Gas Kitchen Range
Igniters don't ignite
I would try cleaning them first. Generally, they should be cleaned periodically. If this does not work then check the igniter.
Feb 09, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Kitchen Ranges Logo
160 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
