Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Light bulb stays on in Kenmore Elite fridge Model # 795.77559600
Just found out this morning that the light bulb in the refrigerator has been staying on. I opened the refrigerator to find the food on the top shelf boiling hot and the light bulb cover melted. I unscrewed the light bulbs as a temporary solution, but would like to have it fixed. Sears "would send a tech out" but will cost us because we are not covered under the warranty anymore. If anyone has a solution, please help. I reported this to the CPSC because this is a SERIOUS fire hazard. I hope that if they get enough complaints, there will be a recall, so please file a report :)!
I had the same problem with a kenmore elite fridge and recieved the same response from Sears customer service!!! File a complaint with your local BBB. Sears contacted me within the day and sending out a tech at their expense only after the complaint was filed. Good luck. Elana
Posted on Aug 13, 2009
  • davey50 Nov 03, 2010
    Try unscrewing the bulbs(without burning your fingers ) wait a few minutes the plug them back in,,it may reset the puter,,By the way this fridge sucked when i bought it and it still sucks
I'm sorry yet glad to hear I am not the only one who had this problem! my fridge actually caught fire! The lights apparently had been on all night and by morning when we found the problem it had started smoking and caught on fire. All of our food had spoiled and was very hot to the touch. The original light bulbs are still in it due to the cover melting over it and not being able to come out. I called it into CPSC hopefully they will take care of the problem!
Posted on Aug 13, 2010
    Try unscrewing the bulbs(without burning your fingers ) wait a few minutes then plug them back in,,it may reset the puter,,By the way this fridge sucked when i bought it and it still sucks
How do I replace the lights in my freezer
Turn off the power to the refrigerator/freezer by flipping the appropriate switch in your breaker panel. Alternatively, unplug the refrigerator from the wall outlet.
Open the freezer door. Remove any items from the shelf directly under the light shield, then remove the shelf.
Press down on the top, front edge of the light shield until the locking tabs slip out of the slots. Swivel the light shield downward slightly to release it. Pull the shield out of the freezer compartment and set it aside.
Turn the light bulb counterclockwise to remove it. Insert the GE replacement bulb into the light socket and twist it clockwise.
5
Reattach the light shield by sliding it into place. Gently push the tabs into the original slots.
6
Insert the shelf into the freezer and reload it with the frozen food removed earlier.
7
Close the freezer door. Restore power to the refrigerator by flipping on the breaker or plugging it into the wall outlet.
Jul 25, 2017 | Freezers
GE side by side refrigerator main light bulb stays on even when door is shut firmly.
There is a switch just inside the door in most on the roof of the fridge, make sure it is not damaged.
Jul 02, 2017 | Refrigerators
Light stays on
Check the door frame for a protruding small lever that gets pushed down when the door closes. If one is visible, that should be the light switch, which probably went bad and needs to be replaced. Without a model # hard to say how the light are set to go off, but most use the above method, hope this helps.
Jan 30, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore Elite front loader model 42198900 , this morning shut the door ,light stayed on and no power to controls, any ideas
Did you ever get an answer to your issue? I am having the same problem. The light stays on when the door is closed and no power to the machine. I have unplugged it and done some other things to no avail. thanks
Jan 27, 2013 | Kenmore Elite 45986 Front Load Washer
LIGHTS STAY ON IN FRIDGE
LG had a problem with the control board going bad allowing the interior lights to stay on even when doors are closed. you need to get in touch with LG concerning repair MY UNDERSTANDING is there is a safety recall and it will be repaired for free. in the mean time unsrew the light bulbs so they dont melt down your liner...
Oct 03, 2012 | LG Refrigerators
Light does not come on when you open door
Test your 40 watt light bulb in another fixture if the light bulb is OK then unplug the refrigerator and open fresh food compartment and pry out the light switch. Test for continuity HERE For some reason your model shows an additional light switch on the control panel located inside the fresh food compartment above top shelf. Try switching the ligh switch on from there. Here is a Photo Click HERE Here is a replacement light switch=> Light-Switch-2149705-00557365 If you have any questions I will be here to answer them for you, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool Gold White-on-White 21.9 cu. ft....
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
1,041 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
