Question about Vizio L32 32 in. LCD HDTV
Our 42 inch vizio hdtv seems to hve the background sounds much louder than the dialoge on movies is there any adjustment to fix this
Vizio VP422 won't turn on ORANGE LIGHT PLEASE HELP*
if you plug in the set, and the "Vizio" light isn't orange, most likely you have a faulty power supply board. Tests will need to be performed to be sure.
Mar 22, 2013 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
42 lcd hdtv vizio has sound but no picture
common problem with no common or single answer===time for a repair shop or a tech.
Sep 03, 2012 | Vizio Televison & Video
I have a 42 inch vizio flatscreen and i have a usb port on it. What is that port used for?
Manual here:
http://vizio.com/documents/downloads/hdtv/VL420M/254User_Manual.pdf
"MEDIA PORT - Insert a FAT/FAT32 formatted USB drive
to view pictures, listen to music, or watch movies."
Can use a USB stick or external hard drive.
Mar 18, 2011 | Vizio 42 in. LCD TV
I have a Hitachi HDTV Ultravision. The sound of music on movies and shows is louder than the show dialoge and is very annolyingly loud. We turn down the commercials and then have to turn it back up when he...
Go into the customer menu for audio---look for settings like Hall etc--one of them is set wrong--experiment a little and you will find which one is wrong---background sound is controlled by this setting.
SD TECH
Sep 21, 2010 | Hitachi 46F510 46" Projection HDTV
Sound bad on hd channels
I ended up installing a stereo graphic equalizer/ sound limiter from Radio Shack. I use the ear phone output go into the equalizer / sound limiter then go into a speaker system. You can adjust the EQ and limit the volume. I also had problems with load portions of movies, commercials and low/ high audio. This also allows sound enhancement with some buttons on the EQ. It is usually used in sound reinforcement as in Band and public address systems also higher end stereos systems. you will need a set of powered speakers for this solution so the EQ has somewhere to go to.
Mar 25, 2010 | Vizio GV42L 42 in. LCD Television
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
I have a 42 inch vizio plasma t.v. and I have power but no sound or picture, I've unplugged it all night and still doesn't work! It's same problen but lcd 47 inch hdtv
hi......it seems that there is some loose connection in the oscillator section.some capacitors in that section have gone faulty.also change the switches in the front panel so itself on& off problem will be solved...thank u rate me!!!
Feb 12, 2009 | Vizio GV42L 42 in. LCD Television
For the 42" plasma, you need to change your sustainer boards or your main board to fix the problem. If your TV is still under warranty, call 877-MY-VIZIO and they will have a technician go to your home and fix the problem for free.
For the L42 HDTV, you need to change the inverter boards or the main board. If your TV is still under warranty, call 877-MY-VIZIO and they will have a technician go to your home and fix the problem for free.
Jan 26, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
Vizio 42" LCD HDTV audio issues
First of all go into the audio menu settings and turn off the "surround" feature off and that should fix the voices/music differences. Does the craking sound appear while watching any sorce such as cable box,sat rcvr or DVD player? If not isolate it to that input and maybe that device is giving the problem.
Feb 21, 2007 | Vizio L37 Television
Vizio L32 32 in. LCD HDTV Logo
270 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
