Question about Garden
My mower isn't running right. I doesn't have much power. It back fires & it uses a lot of gas. It sound loud like something is wrong with the muffer but I checked it and it seem to be ok. I have a Troy Bilt Pony 689 riding lawn mower. Thanks
    President:
  • 1,273 Answers
It sounds like your timing's off. Take the sheetmetal cowl off and remove the flywheel on top. Check your shear pin and replace if necessary. It sounds like there is some offset there. The shear pin should get you back running right. Best regards, --W/D-- please feel free to rate this solution! Thanx!
Posted on Jul 30, 2009
Mower won't start. changed oil, plugs, cleaned carb. i have fire, gas, and air, but won't hit?
Did you clean the fuel jet in the carb? If not that could be the trouble.
Pull the spark plug and put a spoon full of clean gas in the plug hole and put your plug back in and hook up the plug wire and try to start. If it fires up and stalls right after then you know you have a fuel problem. Is your primer bulb working? Sometimes I prime my one engine twenty times before it will run. Worth a try. Make sure you are using fresh gas as well.
Apr 12, 2015 | Garden
I have a craftsman 775 series mower and it fires up fine right on the first pull then slowly dies, I noticed that the throttle isn't holding its position and once it kicks back it dies. Any suggestions?
If you restart it immediately after it stalls will it run for a lot less time then if you leave it for a few minutes?
I'm thinking the needle valve or seat are screwed up by this Ethanol gas and the flow of gas to fill up the Fuel bowl is slower than it should be. I just went through this.
Aug 10, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Toro Personal Pace sounds like it is running at half power
got oil in it, or do you add oil. Left outside alot, fuel line clogged. Is the gas old. Check the blades and the exit portion of the clippings. Does it have a drive train for ease of moving. those can bog down a mower. good luck
Apr 30, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
I have a craftsman lawn tractor that isn't
check the compression if ok is the gas getting threw the carb spray carb cleaner in the carb with the air filter off and crank it over and see if it fires if so the problem is in the carb
Sep 02, 2012 | Garden
Craftsman 26 hp Kohler engine 54
to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
Jul 27, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
Have Honda HRB215 mower. Fired right up first use this season and operated fine. Week later fires first pull then dies after couple seconds. Drained gas and replaced, checked fuel filter, gas lines etc....
Have you checked the spark plug? Mine was doing the same thing. Not staying cranked and sputtering while running. I changed the plug and it runs like new. Hope this helps
Jul 11, 2012 | Garden
My cub (GT2186-44) starts up but immediately shuts down after you release the ignition switch. The engine is pumping fuel but is not getting to the carbuerator, I tried replacing the ignition switch &...
if what you are saying is true that it starts and runs till you let off the key, then your ign switch is at fault. check this with a test light or d.v.m. to see if your coil + has 12 volts to it with the key in the RUN position. sometimes I have seen power while cranking then when you release key the power goes out..or eng stops cause switch doesn't have power to coil in RUN position, keep in mind there are lots of different Ign switches out there, make sure you replaced it with the right kind, use your test light to diagnoise
Jul 27, 2011 | Cub Cadet Street Sign- tractor lawn riding...
TORO 6.5 RUNS FOR 4 SECONDS AFTER PRIMING THEN DIES.pUT IN NEW SPARK PLUG,new gas,but after priming run for several seconds.. it dies again....can you help...sounds like dirt in carb??/ It had run...
Did you check the filter? If the engine doesn't get air they it could cause it to die out like that. Also make sure that there isn't anything in the air line to the carb.
Did you check the gas line and make sure that you are getting enough fuel?
Jun 05, 2011 | Toro Lawn Mower With Toro Power Tools
83 honda silverwing was running fine. stopped and got gas and started funny like half power for half the ride home, then takes off. replaced both spark plugs and was running fine for about 2 miles. noticed...
sounds like a spark problem ,coils once the carbs load up it takes off and the extra fuel in the cylinder is not fireing so you get a back fire check the plug gaps and make sure it;s the right plug , then check to see what kind of spark you have if it's weak replace the coils
Aug 07, 2010 | Honda Silverwing 600 Motorcycles
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
