Question about Whirlpool Calypso GVW9959K Top Load Washer
Water pump out??
It is giving a "FL" message and making a stange noise and won't drain the water. It might be the pump?
  • 4 Answers
The washer filled with too much water, causing a switch to trip. Then everything stops. It tries to drain during FL but if it can't drain, the washer powers down.Choose Drain & Spin to let the washer drain. Then you have to take the washer apart. Fix the problem. I personally can't tell you what to do because I don't own a Calypso.
POSSIBLE CAUSES:
Bad Pump
High Water Flow
Other Causes
Posted on Jul 31, 2009
Code letters FL comes up and makes clicking sound
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Oct 17, 2012 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
It wont work it flashes fl
the Fl code indicates an overfill condition. If the washer is empty, then you likely have a problem with the water level pressure switch. If the washer is full of water and will not drain, you likely have a problem with the drain pump or the washer drain line.
If the washer is full of water, make sure that the washer drain is clear and working properly. Check the drain hose for kinks or clogs. If you find no problems with these issues, I recommend that you manually drain the washer using a wet/dry shop vacuum. Check the drain pump and connecting hoses for problems. You may need to replace the drain pump of water will drain out of the washer properly but the pump will not work properly. A clog in the check ball assembly at the bottom of the tub can also prevent the washer from draining properly.
Aug 11, 2011 | Maytag Neptune MAH5500B Front Load Washer
Pump Problem with Calypso. I was getting the FL code on my washer so having read all the suggestions on the internet I removed the pump assembly and checked for obstructions, nada. Impeller is...
FL Flood Condition FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Jun 04, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
GETTING AN ERROR MESSAGE OF FL, WHAT DOES THIS MEAN?
This means that your Washer has somehow Over Filled with water and will "FL"ood if it does not drain the excess water:
It should also be beeping every 10 seconds and the pump should start to empty some water to rectify the issue.
Restart the machine machine as required or push the overfill reset switch.
To avoid flooding, you might need to temporarily shut the water supply if water continues to flow in the machine while the "FL" code is displayed.
Hope it helps let me know how you go.
Sep 28, 2010 | Kenmore Elite 21082
Calypso washing machine will not start... about 10 years old.. used to reset when i blew into the water level sensor - would show FL, then somehow rest itself.. not now it shows FL, can only get rid of the...
Flood Condition:
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%!#
Aug 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Gives code FL - how do I reset this problem
Flood Condition:
Dec 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL code and 1" of water won't drain
Every time mine does this it has strings stuck in the pump. Remove the pump and either take it apart on puld the junk out of it it or do what I did and go to FirstSource pay 10% for a life time waranty and buy a new pump. I've replace it about once a year. Check the seal around the swashplate in the bottom of the drum it may need to be replaced along with the u-joint. If this is worn it allows more **** to be sucked into the pump. I never buy whirlpool again. I have 2 appliances that give me constant grieve a whirlpool flame lock water heater and this expensive piece of junk.
Aug 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
The washer will not drain, and gives a FL message.... It will not reset... How can I fix it?
Flood Condition:
Feb 23, 2009 | Kenmore 22422 Top Load Washer
Kenmore elite washer problem
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
FL error code started and cannot be cleared except when machine is unplugged. It starts again when plugged in and any cycle is selected. There is a little water in the bottom of the tub that hasn't...
If there is water in the tub and the machine gives an FL code, it should try to drain the tub by turning on the pump motor. On mine when it failed, the pump motor would come on, but the water wouldn't move. In my case it turned out to be sheared impeller splines. I epoxied the motor shaft onto the impeller. If you aren't hearing the motor run, it may be a bad motor, connection or control.
Nov 08, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
192 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
