Television still wont turn on?
I have a Mitsubishi 50 inch, after I changed my lamp the TV still has a blinking yellow light and it wont let me turn on the power
  • 167 Answers
I really need the model number to know for sure. But it could be the wrong lamp or a bad Ballast. Worst case scenario would be a bad light engine ($800)
Posted on Jul 30, 2009
Mitsubishi dlp tv wd65837 wont turn on.
Hello Ejaz,
You will also probably need to change the blown fuse for the lamp also located near the lamp. The blinking orange led is just showing that the circuitry cannot sense any light output yet!
Good Luck!
Rich Lilja
Mar 26, 2015 | Mitsubishi Televison & Video
Blinking yellow light on Mitsubishi wd 57731
Based on the service manual:
Blinking yellow= Lamp cover is open.
It could be something else!
www.aaatvservice.com
Aug 09, 2014 | Mitsubishi WD-57731 57" Projection HDTV
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 25, 2012 | Mitsubishi WD-60737 TV
I recently replaced a 915P026010 bulb for a MiTSUBISHI WD-62628 tv and it gives me a blinking yellow light in the lamp led indicating that the lamp housing is not installed properly. I have re-installled...
Make sure lamp cover is also fixed on tv cabinet after lamp installation.
If lamp cover has not been put on its place, tv wont turn On due to safety switch inside that place that gets press with lamp cover.
Thanks.
Jun 24, 2011 | Televison & Video
Power button blinking yellow tv wont turn on
amystrawn,
Usually a blinking yellow light means the lamp needs changed. If it has not been changed in the last 3 years it should be anyway. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains the hows and whys of changing the lamp as well as where to get the lamps at the best price/quality.
Thanks for using FixYa and for the great rating.
hardrocko
Jun 24, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Just changed the lamp and the "status" light is
you must install the lamp door after lamp replacement to get the "yellow" blinking to stop. if the status is blinking red then you may be having a fan failure internal to the tv. also make sure that the side filter door is installed and secure
Dec 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Yellow light keeps blinkingand the tv wont turn on
If the status light is blinking yellow it means the filter cover is open ( On the left side of televison)
If the lamp light is blinking yellow it means the lamp cover door is open. ( Behind front lower panel) If both covers appear intact the switches may be defective or not engaging properly.
Dec 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Jul 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
221 people viewed this question
Top Televison & Video Experts
Electro Med Services...
